DWC Progress Question
Question about the progress displays.
In the attached screenshot, the red boxes highlight what seems to be a bug. The layer count shows we're at 520 of 894, but the Layer Chart is only updated through Layer 273. Any thoughts on why that might be and/or if it really is a bug?
-Ben
What firmware and DWC version are you using?
Can you share the example gcode file?
DWC 2.1.0
Board: Duet 3 MB6HC (MB6HC)
Firmware: RepRapFirmware for Duet 3 MB6HC 3.1.1 (2020-05-19b2)File:
https://www.dropbox.com/s/xfxyj7xei4st8up/Rebuild BLTouch Radius_0.1mm_PLA_.gcode?dl=0
@benha said in DWC Progress Question:
DWC 2.1.0
Is that correct?
If so, please update to 3.1.1, by uploading this zip file as is to the /sys folder in DWC.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/DuetWebControl-SD-3.1.1.zip
Heh, I guess so. Weird. I thought I updated everything correctly when I set this up a week ago, but I guess the DWC is still ancient.
Stand by...
