    Chimera bed tilt
    • Ozzzzzzyundefined
      Ozzzzzzy
      If I wanted to tilt the bed on a tool change with a chimera to give one side some extra room would I need to disable the mesh bed and re enable it after the bed movement or is there anything else. (Dual independent Z). So in tpre I want to lower one side and then in tfree I want to bring it back to normal. Just to experiment. Im on RRF 3.1.1.
        For your purposes I don't think you would need to disable mesh compensation. You just want to move it out of the way, so it's not accuracy critical.
