Doesn't show custom axes correctly
Hi, i have an A and C (instead of U and V) axes configure in my rrf but the screen shows an U and V axes instead of A and C so it's not controllable with the screen... Is there a fix planned in a next version of paneldue or any easy fix ?
Paneldue 7i with 1.24 firmware on a duet wifi.
What firmware version are you using?
Please post your config.g
Hi, sure. I'm using RRF 2.01 (i know, i will upgrade to RRF3 ^^)
Here is the config.g
config-2.g
I suggest you update to 2.05.1 first. It won't require nearly as much work as upgrading to RRF3.
I'm not sure if updating will resolve your issue, but as a matter of course it will make further troubleshooting easier.
Also review the docs for M584 on creating additional axis.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M584_Set_drive_mapping
Is there any particular reason why you want to use A and C instead of the normally expected U and V?
PanelDue is pretty strict on how it interprets things like heaters. This may also extend to additional axis.
On my way to update to RRF3
I use A and C because it's a CNC and that's the names of the axes i have on most CNC Software ^^
Work is in progress to address this. The new PanelDue firmware will require RRF 3.1 or later, and it will be too large to run on the older version 1.x and some 2.x PanelDue boards.
