Random loss of the extruder
  • Good morning all
    I have a problem my config works well but I randomly lose the extruder.
    card: Duet 2 wifi
    screen: 5 inches with Paneldue
    printer: Core xy home made
    I indicated several times in config.g T0 but it still ended up not being lost and in a completely random way:
    I was able to print 3 hours and 2 minutes from the end of the print loss of T0
    "Error: Attempting to extrude with no tool selected."
    please help me i love the functions of the duet !
    My configuration :
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Jul 19 2020 13:14:37 GMT+0200 (heure d’été d’Europe centrale)
    M550 P"MyXCore 300 Duet" ; set printer name
    M669 K1 ; select CoreXY mode
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M350 X32 Y32 Z32 E16 I1 ; configure microstepping with interpolation
    M92 X160.00 Y160.00 Z800.00 E111.85 ; set steps per mm
    M566 X900.00 Y900.00 Z20.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z200.00 E1200.00 ; set maximum speeds (mm/min)
    M201 X800.00 Y800.00 Z25.00 E250.00 ; set accelerations (mm/s^2)
    M906 X1100 Y1200 Z900 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X300 Y300 Z300 S0 ; set axis maxima
    M574 Z1 S2 ; configure Z-probe endstop for low end on Z
    M558 P1 C"!zprobe.in" H5 F200 T6000 ; set Z probe type to unmodulated and the dive height + speeds
    M558 H5 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
    G31 P500 X32 Y-70 Z3.30 ; set Z probe trigger value, offset and trigger height
    M557 X10:270 Y30:250 S40 ; define mesh grid
    ; Fin
    T0 ; choix outil
    M501 ; lecture des paramètres enregistrés
  • Moderator
    @seb007 said in Random loss of the extruder:
    Can you share the gcode file you were printing?
  • CFFFP_occhiale_ale_5.gcode
    Thank you for your answer, I have the linked file.
    I did include the T0 in my gcode file but it ended up losing the tools.
    I have a smaller file but it works like no other.
  • Moderator
    @seb007 I can't see anything particularly wrong with this gcode file. There are no other tool change commands. Is this the file from the SD card? If not, I think maybe the file on the SD card may be corrupted. This could be caused by an error in transfer, or because of a corrupt SD card.
    Please send M122 to the Duet and post the response. See https://duet3d.dozuki.com/Wiki/SD_Card#Section_Troubleshooting_SD_Card_issues to test the SD card and SD socket.
    What version of DWC are you using? Select Settings > General in DWC to see the version. Are "CRC32 checksums for uploads" enabled? See Settings > Machine-Specific > Communication.
  • m122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
    Board ID: 08DJM-9178L-L2MSD-6JKD2-3S86L-K9DGN
    Used output buffers: 3 of 24 (11 max)
    Static ram: 27980
    Dynamic ram: 93868 of which 52 recycled
    Exception stack ram used: 264
    Never used ram: 8908
    Tasks: NETWORK(ready,404) HEAT(blocked,1224) MAIN(running,1880) IDLE(ready,80)
    Owned mutexes: WiFi(NETWORK)
    Last reset 00:01:20 ago, cause: power up
    Last software reset at 2020-08-18 16:50, reason: User, spinning module GCodes, available RAM 8620 bytes (slot 3)
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
    Error status: 0
    MCU temperature: min 32.1, current 35.6, max 35.9
    Supply voltage: min 24.1, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
    Date/time: 2020-08-19 17:14:42
    Cache data hit count 132751524
    Slowest loop: 4.76ms; fastest: 0.13ms
    === Storage ===
    Free file entries: 10
    SD card longest read time 2.6ms, write time 0.0ms, max retries 0
    Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
    === MainDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
    === AuxDDARing ===
    Heater 1 is on, I-accum = 0.0
    Segments left: 0
    Movement lock held by null
    HTTP is idle in state(s) 0
    Telnet is idle in state(s) 0
    File is idle in state(s) 0
    USB is idle in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    Daemon is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 112.81ms; fastest: 0.00ms
    HTTP sessions: 1 of 8
    • WiFi -
      Network state is active
      WiFi firmware version 1.23
      WiFi MAC address 2c:f4:32:3e:e9:76
      WiFi Vcc 3.36, reset reason Unknown
      WiFi flash size 4194304, free heap 22672
      WiFi IP address 192.168.1.68
      WiFi signal strength -54dBm, reconnections 0, sleep mode modem
      Socket states: 0 4 0 0 0 0 0 0
    here is my M122
    I use the web interface I do not use the SD card.
  • Moderator
    The gcode files you upload via the web interface end up on the SD card in the Duet.
    So please check the things that droftarts mentions.
    Your DWC version should be 3.1.1.
  • thank you I will test and come back to you
