UNSOLVED Ethernet not working
Duet2 Ethernet controller will not communicate via ethernet.
CONFIG below. There are no leds lit on the RJ45 ethernet plug which I am suspicious.Thanks
Jeff
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet Ethernet 1.02 or later
Board ID: 08DJM-9178L-L2MSD-6JKDD-3SJ6K-98H2R
Used output buffers: 1 of 24 (1 max)
Static ram: 25712
Dynamic ram: 92460 of which 164 recycled
Exception stack ram used: 256
Never used ram: 12480
Tasks: NETWORK(ready,1980) HEAT(blocked,912) MAIN(running,3824) IDLE(ready,160)
Owned mutexes:
Last reset 00:01:10 ago, cause: reset button or watchdog
Last software reset details not available
Error status: 0
Free file entries: 10
MCU temperature: min 35.4, current 36.6, max 36.8
Supply voltage: min 1.6, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
Driver 0: ok, SG min/max not available
Driver 1: ok, SG min/max not available
Driver 2: ok, SG min/max not available
Driver 3: ok, SG min/max not available
Driver 4: ok, SG min/max not available
Cache data hit count 118742677
Slowest loop: 0.18ms; fastest: 0.05ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
=== DDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is ready with "M122" in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 0.24ms; fastest: 0.01ms
HTTP sessions: 0 of 8
Interface state 2, link down
ok
M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2020-02-09b1
ok
m552 S1 P192.168.125.100
ok
m552
Network is enabled, configured IP address: 192.168.125.100, actual IP address: 192.168.125.100
ok
M586 P0 S1
HTTP is enabled on port 80
ok
Network running, IP address = 192.168.125.100
@JKonopacki what is the Duet’s Ethernet connected to? A network router, or direct to a PC? If it’s direct to a PC, there are additional setup steps.
A good Ethernet cable needs to be connected, and the connection at the other end turned on, before turning on the Duet.
Ian, Thanks for the reply. I was successful getting the controller on the network, however as I do not know the typical behavior Im not confident with the results. I tried using YAT and sending the 552, 553, and 554 codes both as a DHCP client and fixed IP which did not work. After sleeping on the problem, I edited the config file with a USB to SD converter. I tried the DHCP client P0.0.0.0 first which did not work. When I use the fixed or assigned IP the unit connects although it takes roughly 15 minutes before It connects (responds to ping). The device does not show up as a DHCP lease on my Ubiquiti router but I can ping it and connect through http: Strange.
@JKonopacki said in Ethernet not working:
can you try fixing the link settings for the port in question to 10mbit full duplex instead of auto negotiate and see if it makes a difference?
i've only tested duet on unifi switch/ap not their routers so could be different compatability
Bearer,
I assume you mean restricting the port on the router to 10mbit vs auto or on the Duet?Jeff
It would have to be on the router/switch
yes, once in a blue moon someone have issues with auto negotiation, but the duet does not have settings for controlling it so it has to be the router/switch if possible. the very long timeout may indicate this is the issue for you so worth a try imho
If that doesn't work, do you have another router/switch just to test with?
Where and when was the Duet purchased?
OK, I set up an old Mikrotik router and the controller connects instantly. Not ideal with the second router as I will need to create a route to this subnet, but workable. Thanks for the help.
Jeff
What brand and model of router was it not playing nicely with?
Ubiquiti Dream Pro with SFP+ to a Dell 1Gbit switch (plugged into switch). If I plug into a Netgear 10/100Mbit switch connected to the Ubiquiti router it works fine.
Jeff
Hmm, so I wonder if it's the 10/100 part that is solving it, or if it just doesn't like something else about the ubiquity.
its usually not a question of 10 or 100 mbit, but the negotiation of it. I usually suggest 10 mbit as it will be faster than the duet's SD interface and more reliable if there is a compounding issue with less than ideal cabling.
so the device is connected to the Dell switch or the dream machine? if the switch that is where the compatibility issue would be most likely, and where disabling auto-negotiation might help.
