    BLtouch v3.1 / Toolboard Resolution!
    • oozeBot
      oozeBot last edited by
      I have just spent the better part of the last three days and nights working on this.. our BLtouch functions, but is in a constant error state when connected to the toolboard and blinks red. It does not self-test at startup and simply adding the self test command to the config does not correct this.
      -- BUT --
      Adding the following to the config allows the BLtouch to successfully complete the self-test and initialize without entering an error state! I suspect this must be some sort of handshake issue within the firmware, but will leave that to the experts.
      M280 P0 S60 ; BLtouch - toggle switch mode
      G4 P1000 ; wait 1 second
      M280 P0 S120 ; BLtouch toggle self-test
      I am in hopes this helps others and Duet can research the root cause. Thanks
      • droftarts
        droftarts administrators @oozeBot last edited by
        @oozeBot Thanks for your workaround. I know @dc42 is looking into the issue.
          @oozeBot, thanks for your workaround. I will refer other users to it. As you may be aware, I have traced the issue to debug messages written to the io0.out pin by the bootloader.
