Pressure Advance in slic3r
Hello everyone,
I am new to this forum.
I am using Duplicator 4,which has sailfish firmware, slic3r for slicing and flexible filament.
can someone please help me as,
1)how to calibrate the pressure advance value?
2)how the E value is calculated in slic3r?
3)whether the pressure advance influences the print quality?Thank you.
You are asking in totally the wrong Forum this is dedicated to Duet Hardware with RRF Firmware suggest you go look in the Reprap Forums for that problem
Also I believe it is being removed from slic3r, it already has been in in the Prusa editions, as the hardware version works better.
