Hotend keeps heeting
I connected a hotend to my duet 2 wifi. If I say in the web control to heat the hotend to a certain temperature, the hotend starts heating but if it reaches the target temperature it doesn't stop heating. Also the max. temperature in the config files(see enclosed file) is 450 degrees celcius but the software gives an error at 250 degrees celcius. Does anyone know how to fix this?[0_1598350426651_config 3.zip](Uploading 100%)
as you have not set a max temperature the default is kicking in. set a max temperature explicitly
