    G10 in Gcode start
    1264
    • pcsentinel
      pcsentinel last edited by
      Hi, I am trying to get both tools to start a print by heating, with Tool 0 going to active temp and tool1 going to standby temp whilst heating at the same time. I've tried
      G28 XYZ ; home all axes
      G90 ; use absolute coordinates
      G21 ; set units to millimeters
      G1 X10 Y10
      T99
      G10 P0 S200 R170
      G10 P1 S210 R180
      M572 D0 S0.02 ; hardware pressure advance
      M572 D1 S0.02 ; hardware pressure advance
      T0
      M109 T0 S200
      but I'm getting spurious results, sometimes they heat at the same time other times tool 0 heats and then Tool 1
      Any help?
        I use this for a single-nozzle prints on a dual nozzle printer:
        M140 S65 ; set bed temperature
        G10 P0 S195 ; set tool 0 active temperature
        G10 P1 R150 ; set tool 1 standby temperature
        T1 ; select tool one momentarily so that it goes to standby when we select tool 0
        T0 ; select tool 0
        M116 ; wait for temperatures
        • pcsentinel
          Hi DC, yes I think the issue may be related to the other post about tool change macros, I have M116 in both tpost0 and tpost1 to wait for stabilisation, that's why I put the T99 at the start. IS there a way of disabling the tool change macros at the start of a print, I thought putting T99 might have done that.
          • DjDemonD
            DjDemonD last edited by
            This is something that needs looking at especially for switching hotends as tool change macros running when they are not wanted causes big problems. There needs to be a gcode to disable/enable tool changes or a switch to bypass running the tool change macros after an M109, G10 etc.. Or even a Tx command.
            www.precisionpiezo.co.uk
              You can change tools using a T command without executing the macros in firmware 1.19beta, and in chrishamm's fork versions 1.17e and later. See https://duet3d.com/wiki/G-code#T:_Select_Tool.
              M109 only causes a tool change if there is an explicit T parameter that is not the number of the current tool, or there is no tool selected. So if you don't want tool change macros run when you execute M109, make sure that the correct tool is selected first.
              • pcsentinel
                Hi DC, sorry being thick here, but how would I rearrange my example:
                G1 X10 Y10
                T99
                G10 P0 S200 R170
                G10 P1 S210 R180
                T0
                M109 T0 S200
                so that tool 0 goes to active and tool 1 goes to standby at the same time?
                • pcsentinel
                  DC any thoughts?
                    Based on the example I gave earlier, this should work
                    T99
                    G10 P1 S0 R180 ; set T1 standby temp, and active temp to 0 to avoid waiting for T1 to heat up when we select it
                    T1 ; turn on T1 so that it will go to standby when we select T0
                    G10 P0 S200 R170 ; set T0 temperatures
                    T0 ; select T0
                    G10 P1 S210 R180 ; set T1 active temperature
                    • pcsentinel
                      Great thanks for the help
                      • pcsentinel
                        Hi Dc, I've now put your code in and its working fine, providing (sorry) that the tools are at ambient or less than a particular value. Because I'm doing a lot of experimental prints then often Tool1 is cooling from the previous print after a cancel. With the code above it seems to still take a while until M116 thinks its stable, what's the logic it uses?
