    Duet 2 Wifi power supply requirements
    CNC
    410
    • Perseveranzeundefined
      Perseveranze
      Hello Hive Mind.
      I plan on building an enclosure for my CNC machine controls (Duet, VFD, relays, and PSU) and was curious what the power requirements for the Duet are while running? Currently, I'm using a 24v/15a 3D printer PSU to run my Duet and in the interest of saving space, I'd like to go with a slimmer DIN-rail mounted PSU that can handle the load.
      On an alternate note, does anyone think that a plastic enclosure with hinder my WiFi signal badly or should I get a booster or swap to an ethernet Duet?
      • Vetiundefined
        Veti
        see
        https://duet3d.dozuki.com/Wiki/Choosing_the_power_supply#Section_Total_power_needed
        Perseveranzeundefined 1 Reply Last reply Reply Quote 0
        • A Former User?
          A Former User @Perseveranze
          @Perseveranze said in Duet 2 Wifi power supply requirements:
          should be fine, a good way to test is to pop the enclosure (without the duet!) in a microwave, if it gets hot then it'll likely attenuate the wifi signal.
            Perseveranze @Veti
            @Veti said in Duet 2 Wifi power supply requirements:
            see
            Yeah, I found that page after I asked the question lol. Thanks though! Turns out I could size down but the cost for a good DINrail PSU is so cost prohibitive, I'll just stick with what I have now.
            @bearer said in Duet 2 Wifi power supply requirements:
            should be fine, a good way to test is to pop the enclosure in a microwave, if it gets hot then it'll likely attenuate the wifi signal.
            I can't tell if this is a joke or serious. This sounds like the "Charge your phone with a microwave" prank. Now I have to google if a microwave blocks WiFi signal lol.
            • A Former User?
              A Former User
              microwaves happen to use roughly the same frequency as 2.4ghz wifi, so its not a joke; pretty much all plastics should be fine - some may contain more water than other and that makes them less ideal (and it would be the water or other additives in the plastic that get heated by the microwave)
                Phaedrux Moderator @A Former User
                Instructions unclear. DuetWifi currently sparking in microwave. Please advise.
                A Former User? droftartsundefined 2 Replies Last reply Reply Quote 0
                • A Former User?
                  A Former User @Phaedrux
                  @Phaedrux said in Duet 2 Wifi power supply requirements:
                  😁 point taken...
                    droftarts administrators @Phaedrux
                    Full power or defrost?!
