    RFF3 Micro stepping
    • duetloverundefined
      duetlover
      Hi everybody
      I'm using E3D Tool Changer with Duet Ethernet+Duex5, RFF3.
      I'm trying to enable microstepping 1/16 for extruders.
      At the moment the config.g have :
      M350 E8:8:8:8 C8 I0
      I tried:
      M350 E16:16:16:16 C8 I0
      and
      M350 E16:16:16:16 I1 C8 I0
      without success (not enough extrusion)
      Did I made it wrong ?
      Do I have to configure an other paremeter?
      Thanks
      • Vetiundefined
        Veti
        did you change your steps per mm?
        the first would be ok
        the second should be
        M350 C8 I0
          duetlover
          Stupid guy I am...Did not change step/mm !
          Thanks!
            If you're using x16 microstepping you should enable interpolation for the quiet and smooth motor operation. Not much reason to use anything but x16 with interpolation on the Duet Wifi.
