Can't access DWC1
Firmware installation
  • undefined
    NiklasP
    I just got a new Duet Wifi and updated to V3.1.1.
    (FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2).
    DWC2 works fine but when I try to access DWC1 I only get this message: Your Duet rejected the HTTP request: page not found
    Check that the SD card is mounted and has the correct files in its /www folder.
    Any ideas how I can fix that/ what could cause this error?
    • undefined
      You can't go that far back. DWC1 is no longer updated and isn't being tested against RRF3. It's just too limited.
      When using RRF3.1.1 you really should be using DWC 3.1.1 for compatibility.
      • undefined
        DWC 1.22.6 might work with RRF3, but it sounds to me that it is not present on your SD card. Is file reprap.htm present in the /www folder?
        • undefined
          https://github.com/Duet3D/RepRapFirmware/releases/download/2.05.1/DuetWebControl-1.22.6.zip
          • undefined
            NiklasP
            Thanks for your replies. I'll check the SD tomorrow. Was just wondering because I used the DWC1 GUI on a different Duet Wifi and RRP3.1.1 prior without an issue. My webcontroll is V3.1.1.. Just finished wiring the board and will check if there are any other issues.
            • undefined
              NiklasP
              So I checked the SDcard and the reprap.htm file was missing.
                A Former User
                reprap.htm.gz is not present in Duet2and3Firmware-3.1.1.zip so if you used it previously with 3.1.1 i'd put my $ on reprap.htm being leftovers after upgrades.
                you could perhaps try install older dwc and then upgrade to 3.1.1 again to see if it remains functional, but i wouldn't be surprised if it broke sooner or later.
                1 out of 7
