Bed compensation condition
  • Hello, I'm optimizing processes and wanted to figure out if it was possible to perform with conditional programming this step:
    if I start printing run G29 S0 instead if I start printing after the previous print (M0) load the map with G29 S1.
    Alternatively I should delete the file map at the end of the program manually, I think there is no possibility to delete it via gcode.
    I know that it may seem useless but in doing so I would avoid some repositioning errors due to the homing of the z-axis. Any help or advice is welcome.
    Thank you
  • Unless you have some issues with your hardware you should not need to create your height map frequently.
    At the start of a print if you set the Z=0 datum using G30 and load the existing height map with G29 S1 things should work well.
  • Moderator
    @fcwilt said in Bed compensation condition:
    Provided you used G30 at the same point before creating the heightmap and your probe is reliably repeatable.
  • @fcwilt, @Phaedrux thank you for the answers.
    So, I tried to make a lot of comparisons of the detected heights and noticed that in some cases I have differences of about 0.1mm. I can not quantify whether it is so much or little but when I start a new print I would like to start from the optimal conditions, instead, in my case, if I canceled last print I would avoid probing the points again because I don't bring the Z axis home.
    Now that I think it would be more logical to start printing after canceling the previous print without even probing or loading the last map, but I don't have much clear how to set instruction in start.g
  • Just to give you an idea of what the code was like
    If M0-false
      G28
      G29
      etc.
      etc.
    G1 X0 Y0 Z1 F5000
    I know it's wrong but it's to have an idea
  • @Marco-Bona said in Bed compensation condition:
    Now that I think it would be more logical to start printing after canceling the previous print without even probing or loading the last map...
    Why do you thing that is more logical?
  • @fcwilt, theoretically it should already be loaded
    Understood.
    I have one macro that is called by the slicer at the start of the print.
    • It starts the hotend and bed to heating
    • It cancels baby-stepping and mesh compensation
    • It homes the printer if needs be
    • When the hotend is up to temp it primes the hotend
    • A pause take place for cleaning the nozzle and bed
    • The Z=0 datum is set using G30
    • The existing height map is loaded using G29 S1
    So it doesn't matter to me if it is a new print or a restart of a canceled print.
    While it may not be the ultimate in efficiency what does it matter given that the actual printing consumes much more time than any other phase.
  • @fcwilt, what your macro does is very similar to what I do at start printing, obviously I do not load the map but start the probing. Nowever I would like to add an additional condition, but I understand that it is not possible
  • I use this code in my homez.g to run automatic tramming (three motor bed) and mesh levelling only if the machine has been off or been reset:
    if move.calibration.numFactors = 0  ; no bed levelling run yet
    	G32
    	M98 P"homing/unsafe-homez.g"
    	G29
    else
    with unsafe-homez.g containing
    G1 X{move.axes[0].max/2} Y{move.axes[1].max/2} F15000    ; move to homing position
    M558 H10 ; careful when homing
    G30      ; home precise with Z-probe
    M558 H3  ; back to speed
