Pi4Duet3 DCS not started & Proximity inputs into IOx.in
Does it work correctly without the proximity switches?
Does it work correctly in standalone mode?
@Phaedrux Yes, when both X- & Y-Prox switches are disconnected, I do not get the DCS error, and can navigate the DWC.
I've not tried to run stand-alone (without the Pi). Is it as simple as unplugging the ribbon cable and powering up?? Since the touch screen is connected to the Pi, and I connect to the Duet via IP through the Pi, how would I be able to view the DWC, or that matter, even know if the DCS is started?? Connect with the microUSB and launch... what??
Standalone mode takes the pi completely out of the equation. I want to know if the proximity switches work correctly in that context.
You would disconnect the Pi ribbon cable, connect the ethernet direct to the duet3, and you would need a separate SD card with /www folder containing the DWC 3.1.1 files, and a /sys folder containing your config files from the pi /sys folder. You can make a copy of all those config files when you are connected to the DWC. select all the files and right click, download as zip.
Once the SD card is populated put it in the Duet3 and power it on. If the config.g has a simple M552 S1 in it, the Duet 3 should get a DHCP address from your router.
You can then connect to it via your browser on a PC with http://duet.local or whatever name you've given the device in config.g. Or get the IP address from the router.
@Phaedrux OK... I'll get started on this now. It may be tomorrow before I can post any results. Thanks!!
@Phaedrux Hi Again... I worked the problem this afternoon: Built the standalone MicroSD card, set the IP address, and fired up the machine. NOTE: It had been off for 23 hours. One of the P-Switches was connected to IO2. Results:
-I could ping the IP, and
-DWC was navigable.Turned off the machine, and turned it back on 10 seconds later. Results:
-No reply from a ping to the IP.
-DWC not reachable (of course)Turned it off, disconnected the P-switch, and powered back up. Results:
-Reply from ping.
-DWC navigable.Connected the other P-switch to the same IO2, and powered up. Results:
-No reply from ping, and DWC not available.
So... the answer to your question is: The system behaves in the same way in Standalone mode as it does in PiDuet mode. Further, the power being off for 20+ hours seems to have some strange effect that allows the DCS to start and DWC to be available on the FIRST power cycle only. The machine will fail 2nd power up cycle. Thus, it appears we have repeatable anomalous behavior (I suspect that's a contradiction in term).
Thanks again!!
David -
Ok thanks. That at least rules out a specific DCS/Pi problem and it's most likely an issue with the proximity sensor itself. Were you able to find a data sheet for it?
@Phaedrux I believe the following is the data sheet for the Prox sensors:
The previous file was empty. Here's the best I can do for a datasheet. It covers a range items in the same product line. Our sensor is highlighted in the PDF: LJ12A3-4-Z/AX Inductive Proximity Sensor Switch NPN DC6V-36V. Output Type NPN NC(normally close)
Thanks. Will have to wait for @dc42 to take a look at the spec sheet.
Greetings All... I decided to cut the proverbial knot and ordered replacement Proximity switches ( LJ12A3-4-Z/Ax 4 mm Cylindrical Inductive Proximity Sensor Detection Switch NPN NC DC6-36V 300MA) on the bet that the ones I have were causing the problem. I received the order today and connected two of them to the Duet in the same fashion. The system powered up properly over several cycles. Victory!!
I consider this issue solved.
Thanks to everyone who supported me through this ornery problem... much appreciated!!
David
Glad that worked out. Can you tell what the main difference between them is?
