    RRF3 seems to ignore PrusaSlicer Acceleration Control
    24
    1.7k
    • Wallyundefined
      Wally
      @dc42 - thank you for the note, the F parameter is indeed in the M563 notes but is buried in the text, probably why I missed that. Can the gcode note be updated in the Wiki to make this more noticeable? That note / coding isn't formatted like other examples in the text. Something like this?
      M563 P0 D0 H1 F0:1
      ; tool 0 uses extruder drive 0 and heater 1. Fan 0 and Fan 1 are mapped to tool 0
        There is already this example:
        M563 P2 D0:1 H1:2 X0:3 F0:2 ; create a tool using extruder drives 0 and 1, heaters 1 and 2, with X movement mapped to both X and U axes and fan 0 mapped to fans 0 and 2
        • toskiumundefined
          toskium
          Just as a heads-up for you all, Merill acknowledged the issue and will have it fixed in Superslicer in the upcoming release.
          See: https://github.com/supermerill/SuperSlicer/issues/450#issuecomment-687650047
          toskium created this issue in supermerill/SuperSlicer
          closed G-Code flavor RepRap produces wrong M204 commands #450
          • garethkyundefined
            garethky
            Just ran into this while debugging a print time discrepancy. There is an issue open with Prusa Slicer so hopefully it gets fixed soon: https://github.com/prusa3d/PrusaSlicer/issues/5599
            natthapolvanasrivilai created this issue in prusa3d/PrusaSlicer
            closed RepRapFirmware Flavor add faulty Acceleration Control G-Code (M204) #5599
