    Need advices about servo-motor/closed-loop
    • tiagomaricateundefined
      tiagomaricate
      Hi people!
      I'd like some advice and tips about an idea.
      I have a Robo R2 3D printer.
      I like the printer area, the visual, and the overall structure.
      But as the boards are "limited", I was thinking on replace the mainboard for a Duet 3 and change the stepper motor by a servo-motor.
      I confess I'm new on printing hardware and still reading a lot and making some experiments with my machine.
      My intention is convert it to high-end equipment.
      Further, the changes will include the hotend and so on.
      So... is this too much overkill? Waste of money/time? Good choice?
      I would be very grateful for some tips and advice on how to improve the printer.
      • maxspongebobundefined
        maxspongebob
        In my opinion, you would not be getting any additional benefits by going to servo's. Also you would probably have difficulty interfacing them to the Duet 3.
        I think your best bet would be to identify what areas you want to improve and solicit suggestions on how that could be done. I have much more experience with upgrading CNC machining centers than with 3D printers, but many of the concepts are the same. There is a saying about polishing a turd, it's still a turd. So, instead of upgrading based on what hardware is available, upgrade based on what improvements you need.
        Good Luck.
        tiagomaricateundefined 1 Reply Last reply Reply Quote 0
          tiagomaricate @maxspongebob
          @maxspongebob in order...
          1 - quality/precision
          2 - silent
          3 - easy to setup/modify
          4 - implement the second extruder
