    Connecting Duet 2 Wifi to network
    • PR1ORundefined
      PR1OR
      Hi there,
      I have previously connected my Duet 2 Wifi to my network but have been having issues so i have reconnected it to my mac using terminal
      When putting in code
      M587 S"your-network-ssid" P"your-network-password"
      i get this returned. Has anyone got any ideas?
      I hope someone can help.
        droftarts administrators @PR1OR
        @PR1OR send M552 S-1 to turn off Wifi module, then M552 S0 to turn it on in idle mode. Send M587 to list current networks, and check it’s responding.
          What terminal are you using on your mac? Some terminal programs send all commands as upper case, which is problematic for case sensitive passwords.
          See the notes here: https://duet3d.dozuki.com/Wiki/Gcode#Section_M587_Add_WiFi_host_network_to_remembered_list_or_list_remembered_networks
