    Solved Axis limits not respecred - Core XY
    • Super08
      Super08 last edited by
      Hello everybody,
      I have a strange issue with my axis limits.
      I have define them for a 330x330x300 print area.
      M208 X330 Y330 Z300 S1 ; set axis maxima
      But for an unknow reason, I'm not able to go further than 200mm on each axis.
      I have try manually or with a g29.
      During G29 it take point only in a 200x200 area.
      My step/mm are correct I have already print a test cube.
      Do I miss something?
      Thank you for your help.
        @Super08 said in Axis limits not respecred - Core XY:
        You've got S1 for both of them. the maxima should be S0
        • fcwilt
          fcwilt last edited by
          Or you can use the alternate form
          M208 Xaaa:bbb Yaaa:bbb Zaaa:bbb
          where aaa is the min for that axis and bbb is the max.
          • Super08
            I definetly missed it...
            Thank you, that work well now!
