    Web Control Look and feel
    Duet Web Control
    2.4k
    • PR1ORundefined
      PR1OR @PR1OR
      @PR1OR dont worry i did it wrong. overwrote all the files by accident.
      I have fixed that now
      UI now looks like this
      • Vetiundefined
        Veti
        that looks correct. and all the values get displayed.
          You can verify the DWC version in the General tab on the left side but that now looks correct for 3.1.1.
          You should now be able to upload the config.zip to the system tab.
          PR1ORundefined 1 Reply Last reply Reply Quote 0
          • PR1ORundefined
            PR1OR @Phaedrux
            @Phaedrux @Veti
            Thanks both i have managed to upload the Config now. However i have a feeling the person i got the zip off may have to many in the same file so now im not sure what should and should be there. Can you confirm this is right?
            https://youtu.be/ioaC-JRMzCQhttps://youtu.be/ioaC-JRMzCQ
              Ok it looks like you have the entire contents of the /www folder in your /sys folder.
              The sys folder should have the .bin files for the firmware and .g files for the config. Everything else with a .gz should be removed.
              • PR1ORundefined
                PR1OR @Phaedrux
                @Phaedrux said in Web Control Look and feel:
                So should i unplug the SD card and sort in to this?
                .bin = sys folder
                .g = gcodes
                .gz = delete
                • PR1ORundefined
                  PR1OR @PR1OR
                  @PR1OR
                  also delete the .json?
                    No you can do it right from the web interface. Put a checkmark next to the .gz files and then right click and delete.
                    Leave the .g files in the /sys folder. Those are the configuration files you would edit, particularly config.g
                      No leave the .json file. It's generated by the web configurator. It's got a list of all your settings that you can use to load up your configuration in the tool again if you wanted.
                      config.g.bak is a backup of the config.g file that gets updated every time you edit it so you can go back one version if you make a mistake.
                      • PR1ORundefined
                        PR1OR @Phaedrux
                        i
                        ok perfect thank you. Thats all done. Now to sort the wiring out (rofl)
                        Im sure we will chat again haha but really appreciate your help!!
