    File Corruption with uploading large files over web interface
    • lee7670undefined
      lee7670
      I'm having trouble getting a 212MB file you upload over the web interface, It keeps getting corrupted and I get errors such as Error: Uploaded file CRC is different (6acd12c1 vs. expected d18ebd88).
      I am using the SD card that came with the duet and I am running RRF3.2beta.
      Here is the M122 output.
      RepRapFirmware for Duet 3 MB6HC version 3.2-beta running on Duet 3 MB6HC v1.01 or later (standalone mode)
      Board ID: 08DJM-956L2-G43S8-6J9FA-3S86J-1B3QF
      Used output buffers: 1 of 40 (23 max)
      Static ram: 154528
      Dynamic ram: 163140 of which 24 recycled
      Exception stack ram used: 320
      Never used ram: 75204
      Tasks: NETWORK(ready,288) ETHERNET(blocked,432) HEAT(blocked,1108) CanReceiv(suspended,3424) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,196) MAIN(running,4536) IDLE(ready,76)
      Owned mutexes:
      Last reset 01:19:03 ago, cause: software
      Last software reset at 2020-09-10 18:58, reason: User, spinning module GCodes, available RAM 75548 bytes (slot 0)
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04437000 BFAR 0x00000000 SP 0xffffffff Task MAIN
      Error status: 10
      MCU temperature: min 30.1, current 32.3, max 32.8
      Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.1, current 12.2, max 12.3, under voltage events: 0
      Driver 0: standstill, reads 39250, writes 15 timeouts 0, SG min/max 0/0
      Driver 1: standstill, reads 39249, writes 16 timeouts 0, SG min/max 0/0
      Driver 2: standstill, reads 39251, writes 15 timeouts 0, SG min/max 0/0
      Driver 3: standstill, reads 39252, writes 15 timeouts 0, SG min/max 0/0
      Driver 4: standstill, reads 39252, writes 15 timeouts 0, SG min/max 0/0
      Driver 5: standstill, reads 39257, writes 11 timeouts 0, SG min/max 0/0
      Date/time: 2020-09-10 20:17:19
      Slowest loop: 1195.04ms; fastest: 0.15ms
      === Storage ===
      Free file entries: 9
      SD card 0 detected, interface speed: 25.0MBytes/sec
      SD card longest read time 4.5ms, write time 364.0ms, max retries 0
      Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms
      === MainDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USBchan is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0 0, running macro
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 1194.75ms; fastest: 0.03ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
      HTTP sessions: 1 of 8
      - Ethernet -
      State: active
      Error counts: 0 0 0 0 0
      Socket states: 5 2 2 2 2 0 0 0
      === CAN ===
      Messages sent 19008, longest wait 1ms for type 6018
      === SBC interface ===
      State: 0, failed transfers: 0
      Last transfer: 4743972ms ago
      RX/TX seq numbers: 0/1
      SPI underruns 0, overruns 0
      Number of disconnects: 0
      Buffer RX/TX: 0/0-0
      Any ideas? I would really like to be able to upload files without cutting power to the machine to remove the SD and losing state.
        Does this occur with 3.1.1?
        What DWC version are you running?
        • lee7670undefined
          lee7670
          It occurs with 3.1.1 also, DWC is 3.1.1
            Can you try with a different SD card?
            Does it happen with just that file or with any large file of that size?
