Solved Duet 3 ToolBoard 1LC - Direct Connection to Duet3 Mainboard 6HC
Does anyone has successfully connected Duet 3 board and Toolboard?
See the picture (original from Duet). It says (under black wire) RJ11 Pin 3 -> JST Pin 4 and (above red wire) RJ11 Pin 4 -> JST Pin 3. But picture (red and black wire) shows connection RJ11 Pin 3 -> JST Pin 3 and RJ11 Pin 4 -> JST Pin 4.
Does anyone know if text descripton is correct or picture is correct?
Text is correct
@bearer Thanks man!
