3.2b1 Duet 3 (DCS is not started)
After updating to 3.2b1 when I try to connect to the web control page I get these errors:
I get the same
My works fine.
@BoA did you do anything other than the update/upgrade?
@Dougal1957 Nope. Updated firmware first, then DWC. Standalone setup if that matters.
@BoA so you didn't do it via the Pi then?
@BoA said in 3.2b1 Duet 3 (DCS is not started):
@Dougal1957 Nope. Updated firmware first, then DWC. Standalone setup it that matters.
Yes that matters both myself and bcrazycramer do use the pi
@Dougal1957 I am running standalone mode.
I suspect there may be a permission issue going on because we changed from
root
to a dedicatedsf
user in the latest pre-release. My best guess how to resolve this, runsudo rm -f /var/run/dsf/dcs.sock
and wait a few seconds.
If that doesn't help, please check the DCS log first:
sudo journalctl -u duetcontrolserver -f
and if that keeps running, check the DWS log:
sudo journalctl -u duetwebserver -f
If it doesn't help, please post the last 20 lines or so from each log dump.
@chrishamm said in 3.2b1 Duet 3 (DCS is not started):
Sep 15 19:35:13 duet3 DuetControlServer[10966]: at DuetControlServer.Model.PeriodicUpdater.Run() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Model/PeriodicUpdater.cs:line 39 Sep 15 19:35:13 duet3 DuetControlServer[10966]: [info] Application has shut down Sep 15 19:35:14 duet3 systemd[1]: duetcontrolserver.service: Succeeded. Sep 15 19:35:19 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=5s expired, scheduling restart. Sep 15 19:35:19 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 386. Sep 15 19:35:19 duet3 systemd[1]: Stopped Duet Control Server. Sep 15 19:35:19 duet3 systemd[1]: Started Duet Control Server. Sep 15 19:35:20 duet3 DuetControlServer[10988]: Duet Control Server v3.2.0-beta1 Sep 15 19:35:20 duet3 DuetControlServer[10988]: Written by Christian Hammacher for Duet3D Sep 15 19:35:20 duet3 DuetControlServer[10988]: Licensed under the terms of the GNU Public License Version 3 Sep 15 19:35:21 duet3 DuetControlServer[10988]: [info] Settings loaded Sep 15 19:35:21 duet3 DuetControlServer[10988]: [info] Environment initialized Sep 15 19:35:21 duet3 DuetControlServer[10988]: [warn] Kernel SPI buffer size is smaller than RepRapFirmware buffer size (4096 configured vs 8192 required) Sep 15 19:35:21 duet3 DuetControlServer[10988]: [info] Connection to Duet established Sep 15 19:35:22 duet3 DuetControlServer[10988]: [info] IPC socket created at /var/run/dsf/dcs.sock Sep 15 19:35:22 duet3 DuetControlServer[10988]: [fatal] Abnormal program termination Sep 15 19:35:22 duet3 DuetControlServer[10988]: [fatal] Periodic updater task faulted Sep 15 19:35:22 duet3 DuetControlServer[10988]: System.UnauthorizedAccessException: Access to the path is denied. Sep 15 19:35:22 duet3 DuetControlServer[10988]: ---> System.IO.IOException: Permission denied Sep 15 19:35:22 duet3 DuetControlServer[10988]: --- End of inner exception stack trace --- Sep 15 19:35:22 duet3 DuetControlServer[10988]: at System.IO.DriveInfo.CheckStatfsResultAndThrowIfNecessary(Int32 result) Sep 15 19:35:22 duet3 DuetControlServer[10988]: at System.IO.DriveInfo.get_TotalSize() Sep 15 19:35:22 duet3 DuetControlServer[10988]: at DuetControlServer.Model.PeriodicUpdater.UpdateVolumes() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Model/PeriodicUpdater.cs:line 144 Sep 15 19:35:22 duet3 DuetControlServer[10988]: at DuetControlServer.Model.PeriodicUpdater.Run() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Model/PeriodicUpdater.cs:line 39 Sep 15 19:35:22 duet3 DuetControlServer[10988]: [fatal] Periodic updater task faulted Sep 15 19:35:22 duet3 DuetControlServer[10988]: System.UnauthorizedAccessException: Access to the path is denied. Sep 15 19:35:22 duet3 DuetControlServer[10988]: ---> System.IO.IOException: Permission denied Sep 15 19:35:22 duet3 DuetControlServer[10988]: --- End of inner exception stack trace --- Sep 15 19:35:22 duet3 DuetControlServer[10988]: at System.IO.DriveInfo.CheckStatfsResultAndThrowIfNecessary(Int32 result) Sep 15 19:35:22 duet3 DuetControlServer[10988]: at System.IO.DriveInfo.get_TotalSize() Sep 15 19:35:22 duet3 DuetControlServer[10988]: at DuetControlServer.Model.PeriodicUpdater.UpdateVolumes() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Model/PeriodicUpdater.cs:line 144 Sep 15 19:35:22 duet3 DuetControlServer[10988]: at DuetControlServer.Model.PeriodicUpdater.Run() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Model/PeriodicUpdater.cs:line 39 Sep 15 19:35:22 duet3 DuetControlServer[10988]: [error] IPC#2: Failed to assign connection processor Sep 15 19:35:22 duet3 DuetControlServer[10988]: System.Threading.Tasks.TaskCanceledException: A task was canceled. Sep 15 19:35:22 duet3 DuetControlServer[10988]: at DuetAPI.Utility.JsonHelper.ReceiveUtf8Json(Socket socket, CancellationToken cancellationToken) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetAPI/Utility/JsonHelper.cs:line 140 Sep 15 19:35:22 duet3 DuetControlServer[10988]: at DuetControlServer.IPC.Connection.ReceivePlainJson() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/IPC/Connection.cs:line 233 Sep 15 19:35:22 duet3 DuetControlServer[10988]: at DuetControlServer.IPC.Server.GetConnectionProcessor(Connection conn) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/IPC/Server.cs:line 173 Sep 15 19:35:22 duet3 DuetControlServer[10988]: [info] Application has shut down Sep 15 19:35:22 duet3 systemd[1]: duetcontrolserver.service: Succeeded.
Sep 15 19:36:39 duet3 DuetWebServer[443]: Executed action DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer) in 17.4835ms Sep 15 19:36:39 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[1] Sep 15 19:36:39 duet3 DuetWebServer[443]: Executed endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)' Sep 15 19:36:39 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Hosting.Diagnostics[2] Sep 15 19:36:39 duet3 DuetWebServer[443]: Request finished in 18.1791ms 101 Sep 15 19:36:40 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Hosting.Diagnostics[1] Sep 15 19:36:40 duet3 DuetWebServer[443]: Request starting HTTP/1.1 GET http://duet3/rr_connect?password=reprap&time=2020-9-15T19%3A36%3A40 application/json Sep 15 19:36:40 duet3 DuetWebServer[443]: info: DuetWebServer.Middleware.CustomEndpointMiddleware[0] Sep 15 19:36:40 duet3 DuetWebServer[443]: No endpoint found for GET request via /rr_connect Sep 15 19:36:40 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Hosting.Diagnostics[2] Sep 15 19:36:40 duet3 DuetWebServer[443]: Request finished in 0.6246ms 404 Sep 15 19:36:40 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Hosting.Diagnostics[1] Sep 15 19:36:40 duet3 DuetWebServer[443]: Request starting HTTP/1.1 GET http://duet3/machine Sep 15 19:36:40 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[0] Sep 15 19:36:40 duet3 DuetWebServer[443]: Executing endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)' Sep 15 19:36:40 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[3] Sep 15 19:36:40 duet3 DuetWebServer[443]: Route matched with {action = "Get", controller = "WebSocket"}. Executing controller action with signature System.Threading.Tasks.Task Get() on controller DuetWebServer.Controllers.WebSocketController (DuetWebServer). Sep 15 19:36:40 duet3 DuetWebServer[443]: fail: DuetWebServer.Controllers.WebSocketController[0] Sep 15 19:36:40 duet3 DuetWebServer[443]: [WebSocketController] DCS is not started Sep 15 19:36:40 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2] Sep 15 19:36:40 duet3 DuetWebServer[443]: Executed action DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer) in 24.4179ms Sep 15 19:36:40 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[1] Sep 15 19:36:40 duet3 DuetWebServer[443]: Executed endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)' Sep 15 19:36:40 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Hosting.Diagnostics[2] Sep 15 19:36:40 duet3 DuetWebServer[443]: Request finished in 25.1331ms 101 Sep 15 19:36:41 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Hosting.Diagnostics[1] Sep 15 19:36:41 duet3 DuetWebServer[443]: Request starting HTTP/1.1 GET http://duet3/rr_connect?password=reprap&time=2020-9-15T19%3A36%3A41 application/json Sep 15 19:36:41 duet3 DuetWebServer[443]: info: DuetWebServer.Middleware.CustomEndpointMiddleware[0] Sep 15 19:36:41 duet3 DuetWebServer[443]: No endpoint found for GET request via /rr_connect Sep 15 19:36:41 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Hosting.Diagnostics[2] Sep 15 19:36:41 duet3 DuetWebServer[443]: Request finished in 0.5723ms 404 Sep 15 19:36:41 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Hosting.Diagnostics[1] Sep 15 19:36:41 duet3 DuetWebServer[443]: Request starting HTTP/1.1 GET http://duet3/machine Sep 15 19:36:41 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[0] Sep 15 19:36:41 duet3 DuetWebServer[443]: Executing endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)' Sep 15 19:36:41 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[3] Sep 15 19:36:41 duet3 DuetWebServer[443]: Route matched with {action = "Get", controller = "WebSocket"}. Executing controller action with signature System.Threading.Tasks.Task Get() on controller DuetWebServer.Controllers.WebSocketController (DuetWebServer). Sep 15 19:36:41 duet3 DuetWebServer[443]: fail: DuetWebServer.Controllers.WebSocketController[0] Sep 15 19:36:41 duet3 DuetWebServer[443]: [WebSocketController] DCS is not started Sep 15 19:36:41 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2] Sep 15 19:36:41 duet3 DuetWebServer[443]: Executed action DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer) in 20.2086ms Sep 15 19:36:41 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[1] Sep 15 19:36:41 duet3 DuetWebServer[443]: Executed endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)' Sep 15 19:36:41 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Hosting.Diagnostics[2] Sep 15 19:36:41 duet3 DuetWebServer[443]: Request finished in 20.8581ms 101 ^C
is this enough chris it just seems to be cycling
Doug
Thanks, it's indeed a permission issue - not sure why this problem didn't show up during our internal tests though. You need to change the service file
/usr/lib/systemd/system/duetcontrolserver.service
in order to fix it to[Unit] Description=Duet Control Server [Service] ExecStart=/opt/dsf/bin/DuetControlServer TimeoutStopSec=15 Restart=always RestartSec=5 Type=simple User=dsf Group=dsf UMask=0002 CapabilityBoundingSet=CAP_SYS_PTRACE CAP_DAC_READ_SEARCH AmbientCapabilities=CAP_SYS_PTRACE CAP_DAC_READ_SEARCH [Install] WantedBy=basic.target
Note the new permission
CAP_DAC_READ_SEARCH
. I'll update the DCS package again tomorrow. -
CAP_DAC_READ_SEARCH
. I'll update the DCS package again tomorrow.Chris can you put that in simple layman's terms please How do I do that?
Thank you! That fixed it.
@Dougal1957 Sure thing, run
sudo curl https://pkg.duet3d.com/duetcontrolserver.service -o /usr/lib/systemd/system/duetcontrolserver.service sudo systemctl daemon-reload
Fixed now thanks (one of the guys in a discord I am in suggested how I could edit it with NANO Thanks Luke
Do you know why this isn't working?
pi@duet3:~$ sudo /opt/dsf/bin/DuetWebServer
crit: Microsoft.AspNetCore.Server.Kestrel[0]
Unable to start Kestrel.
System.IO.IOException: Failed to bind to address http://[::]:80: address already in use.
---> Microsoft.AspNetCore.Connections.AddressInUseException: Address already in use
---> System.Net.Sockets.SocketException (98): Address already in use
at System.Net.Sockets.Socket.UpdateStatusAfterSocketErrorAndThrowException(SocketError error, String callerName)
at System.Net.Sockets.Socket.DoBind(EndPoint endPointSnapshot, SocketAddress socketAddress)
at System.Net.Sockets.Socket.Bind(EndPoint localEP)
at Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets.SocketConnectionListener.Bind()
at Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets.SocketTransportFactory.BindAsync(EndPoint endpoint, CancellationToken cancellationToken)
at Microsoft.AspNetCore.Server.Kestrel.Core.KestrelServer.<>c__DisplayClass21_01.<<StartAsync>g__OnBind|0>d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.AddressBinder.BindEndpointAsync(ListenOptions endpoint, AddressBindContext context) --- End of inner exception stack trace --- at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.AddressBinder.BindEndpointAsync(ListenOptions endpoint, AddressBindContext context) at Microsoft.AspNetCore.Server.Kestrel.Core.ListenOptions.BindAsync(AddressBindContext context) at Microsoft.AspNetCore.Server.Kestrel.Core.AnyIPListenOptions.BindAsync(AddressBindContext context) at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.AddressBinder.EndpointsStrategy.BindAsync(AddressBindContext context) at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.AddressBinder.BindAsync(IServerAddressesFeature addresses, KestrelServerOptions serverOptions, ILogger logger, Func
2 createBinding)
at Microsoft.AspNetCore.Server.Kestrel.Core.KestrelServer.StartAsync[TContext](IHttpApplication1 application, CancellationToken cancellationToken) Unhandled exception. System.IO.IOException: Failed to bind to address http://[::]:80: address already in use. ---> Microsoft.AspNetCore.Connections.AddressInUseException: Address already in use ---> System.Net.Sockets.SocketException (98): Address already in use at System.Net.Sockets.Socket.UpdateStatusAfterSocketErrorAndThrowException(SocketError error, String callerName) at System.Net.Sockets.Socket.DoBind(EndPoint endPointSnapshot, SocketAddress socketAddress) at System.Net.Sockets.Socket.Bind(EndPoint localEP) at Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets.SocketConnectionListener.Bind() --- End of inner exception stack trace --- at Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets.SocketConnectionListener.Bind() at Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets.SocketTransportFactory.BindAsync(EndPoint endpoint, CancellationToken cancellationToken) at Microsoft.AspNetCore.Server.Kestrel.Core.KestrelServer.<>c__DisplayClass21_0
at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.AddressBinder.BindAsync(IServerAddressesFeature addresses, KestrelServerOptions serverOptions, ILogger logger, Func2 createBinding) at Microsoft.AspNetCore.Server.Kestrel.Core.KestrelServer.StartAsync[TContext](IHttpApplication
at Microsoft.AspNetCore.Hosting.GenericWebHostService.StartAsync(CancellationToken cancellationToken)
at Microsoft.Extensions.Hosting.Internal.Host.StartAsync(CancellationToken cancellationToken)
at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.RunAsync(IHost host, CancellationToken token)
at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.Run(IHost host)
at DuetWebServer.Program.Main(String[] args) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetWebServer/Program.cs:line 24
Aborted
pi@duet3:~$ -
@bcrazycramer It looks like there is another web server running on the same port (80). Do you have Apache or another HTTP server installed on your system? If not, try rebooting the Pi and check if that makes a difference.
PS: DWS will usually run in the background as its own service, so there should be no need to start it manually. Follow my last reply describing the usage of
journalctl
to figure out why DCS/DWS isn't started. -
I get the same after rebooting.
I'm not using the Raspberry Pi for anything else except the Duet 3. I do have VNC enabled and SSH.
@bcrazycramer Please see my earlier post where I mention journalctl.
[edit]Sorry, linking posts doesn't seem to work too well[/edit]
@bcrazycramer I get the same as well not that I have a clue what it means!
