Solved Z offset for dual extruder
I have dual extruder setup where one of them is lifting up when second extruder is used.
So E0 is low and moves up when E1 is used by moving U axis, therefore there need to be 3.5mm offset on Z axis for E0
I tried to implement Z offset in config.g using G10 P0 X0 Y0 Z3.5 U0 - it worked for offset but messed my printer and it Z axis wouldn't move during print anymore, printing only using X and Y axis.
Is there any other way I can implement this offset? I'm very basic with gcode.
the first extruder should not have an offset.
define the offset for the second extruder. -
You're right, adjusting offset on E1 doesn't mess printer in the way E0 does.
I swapped connections between E0 and E1 and it works fine now thanks.Its very weird that E0 does this, I took me a while to figure out it was Z offset on E0 causing that.
@Veti I just printed calibration cube and it came out 3.5mm too short, missing bottom layers.
Z axis doesn't work until it reaches offset height I setup on E1: G10 P1 X0 Y0 Z3.5 U0edit:
I removed offset from G10 command and instead in Cura in extruder2 start g-code I added:
G1 Z3.5
G92 Z0
This did the trick, now I have to find way to implement it in duet config file. It works fine but I prefer to not rely on Cura to execute this command. -
can you adjust the minimum
from something like this
to
M208 X0 Y0 Z-3.5 S1 ; set axis minima
