RRF 3.2 Beta 1 not recovering from Pause event
  • I am running RR3 3.2 beta 1 on a duet 3 with SBC
    DSF Version 3.2.0-beta1+1
    DWC Version 3.2.0-beta1+2
    I've been changing slicer and as of yet, its not waiting for the tool to heat on beginning a print. To mitigate that, once the print begins, I pause the print until the tool is at the correct temperature.
    On resuming the print, nothing happens.
    Here is an output from M122
    m122
    RepRapFirmware for Duet 3 MB6HC version 3.2-beta1 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
    Board ID: 08DJM-956L2-G43S4-6J1DL-3SJ6N-186LG
    Used output buffers: 1 of 40 (14 max)
    Static ram: 154820
    Dynamic ram: 135280 of which 44 recycled
    Exception stack ram used: 528
    Never used ram: 102544
    Tasks: HEAT(blocked,276) CanReceiv(blocked,874) CanSender(blocked,336) CanClock(blocked,352) TMC(blocked,18) MAIN(running,719) IDLE(ready,19)
    Owned mutexes:
    Last reset 05:35:03 ago, cause: software
    Last software reset at 2020-09-17 08:01, reason: User, LinuxInterface spinning, available RAM 103272, slot 0
    Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
    Error status: 0x020
    MCU temperature: min 31.6, current 34.5, max 35.9
    Supply voltage: min 26.8, current 27.0, max 27.1, under voltage events: 0, over voltage events: 0, power good: yes
    12V rail voltage: min 11.3, current 12.1, max 12.1, under voltage events: 0
    Driver 0: position -12322, standstill, reads 60649, writes 8 timeouts 0, SG min/max 0/1023
    Driver 1: position -4724, standstill, reads 60649, writes 8 timeouts 0, SG min/max 0/1023
    Driver 2: position 45121, standstill, reads 60646, writes 10 timeouts 0, SG min/max 0/1023
    Driver 3: position 8740, standstill, reads 60647, writes 10 timeouts 0, SG min/max 0/1023
    Driver 4: position 0, standstill, reads 60647, writes 10 timeouts 0, SG min/max 0/1023
    Driver 5: position 0, standstill, reads 60647, writes 10 timeouts 0, SG min/max 0/1023
    Date/time: 2020-09-17 13:37:02
    Slowest loop: 7.91ms; fastest: 0.21ms
    === Storage ===
    Free file entries: 10
    Hiccups: 0(0), FreeDm: 375, MinFreeDm: 324, MaxWait: 13507717ms
    === MainDDARing ===
    Scheduled moves: 82, completed moves: 82, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
    === AuxDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
    Heater 0 is on, I-accum = 0.6
    Heater 2 is on, I-accum = 0.0
    Segments left: 0
    Movement lock held by null
    HTTP* is ready with "M122" in state(s) 0
    Telnet is idle in state(s) 0
    File* is idle in state(s) 0
    USB is idle in state(s) 0
    Aux is idle in state(s) 0
    Queue* is idle in state(s) 0
    LCD is idle in state(s) 0
    SBC is idle in state(s) 0
    Daemon* is idle in state(s) 0
    Aux2 is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 0.00ms; fastest: 5726623.00ms
    Responder states:
    HTTP sessions: 0 of 8
    - Ethernet -
    State: disabled
    Error counts: 0 0 0 0 0
    === CAN ===
    Messages sent 156069, send timeouts 156069, longest wait 5ms for type 6029, free CAN buffers 48
    === SBC interface ===
    State: 0, failed transfers: 0
    Last transfer: 18ms ago
    RX/TX seq numbers: 45968/45970
    SPI underruns 0, overruns 0
    Number of disconnects: 0
    Buffer RX/TX: 0/0-0
    === Duet Control Server ===
    Duet Control Server v3.2.0-beta1+1
    Code buffer space: 4096
    Configured SPI speed: 8000000 Hz
    Full transfers per second: 31.63
    File /opt/dsf/sd/gcodes/Inch - Spur gear 14DP 16T 20PA 0.5FW ---S16N3.0H2.0L0.375N.gcode is selected, processing
  • Hello,
    I have a similar issue. I paused a print, the tool goes back to X0 Y0 as expected then I resumed the print, the tool goes back to the last printing position and stays there.
    I tried to pause and resume multiple times but the print never continued, I had to stop it.
  • Same here. Goes back to last printing position and stops there.
    Thanks for the report, I am looking into it.
  • Same problem for me with M600: filament-change.g is executed and the extruder is moved to the desired position. When resuming the print, the extruder us moved back to its original position and nothing happens.
    Then, after a while, I get a "Finished Printing" notification.
    I was able to find the reason for this and it is going to be fixed in 3.2-b2.
