G29 command doesn't do anything on version 3.2 beta 1
  • Hello,
    I updated my printer to the 3.2 beta 1 version and I have a problem with the G29 command.
    Board: Duet 3 MB6HC (MB6HC)
    DSF Version: 3.2.0-beta1+1
    Firmware: RepRapFirmware for Duet 3 MB6HC 3.2-beta1 (2020-09-15b1)
    Duet Web Control 3.2.0-beta1+2
    The G29 command doesn't do anything anymore (neither does the "Run Mesh Compensation (G29)" button in DWC). But G29 S0 works as expected.
    I don't have a mesh.g file so if I understand correctly the changelog:
    G29 with no S parameter now runs file sys/mesh.g if it exists; otherwise it behaves like G29 S0 as before
    G29 is supposed to act like a G29 S0, no?
  • G29 on its own now runs mesh.g I believe.
  • @jay_s_uk Yeah that's what the changelog seems to indicate but I don't have a mesh.g file so I thought it was supposed to behave like a G29 S0
    @jay_s_uk said in G29 command doesn't do anything on version 3.2 beta 1:
    If mesh.g is not found then G29 should behave the same as G29 S0. It sounds like this part of the functionality does not work when using an attached SBC.
