Solved GCode cancelling immediately
[0_1600705645386_JocelynSign1.nc](Uploading 100%) [0_1600705627775_config.g](Uploading 100%) Hello,
I have finally got my machine to the point that I am ready to cut. I am using a 1515 workbee from Bulkman. With a Duet 3 and a VFD controlled spindle. When I go to carve my first set of Gcode, I get a message saying cancelled printing file immediately. I'm not sure what I have set up wrong. I have attached my config files as well as the gcode i'm trying to run. Any help would be greatly appreciated.[0_1600705618404_config.json](Uploading 100%)
Realized I cannot attach files. Heres beginning of my GCode :
(JocelynSign1)
G21
G90(Engrave1)
G0 X66.040 Y-17.860 Z15.000
G0 X66.040 Y-17.860 Z4.000
G1 X66.040 Y-17.860 Z-2.270 F1000
G1 X66.037 Y-18.002 Z-2.270 F1000My Config File:
; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Aug 30 2020 01:47:07 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"Duet 3" ; set printer name; Drives
M569 P0.3 S1 ; physical drive 0.3 goes backwards
M569 P0.4 S1 ; physical drive 0.4 goes forwards
M584 X0.3 Y0.0:1 Z0.4 ; set drive mapping
M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
M92 X400.00 Y400.00 Z400.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z12.00 ; set maximum instantaneous speed changes (mm/min)
M203 X4800.00 Y4800.00 Z180.00 ; set maximum speeds (mm/min)
M201 X350.00 Y350.00 Z100.00 ; set accelerations (mm/s^2)
M906 X2200 Y2200 Z2000 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X1300 Y1300 Z60 S0 ; set axis maxima; Endstops
M574 X2 S1 P"io0.in" ; configure active-high endstop for low end on X via pin io0.in
M574 Y2 S1 P"io1.in" ; configure active-high endstop for high end on Y via pin io1.in
M574 Z1 S1 P"io2.in" ; configure active-high endstop for low end on Z via pin io2.in
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M106 F-1 C"OUT9" ; Disable fan Out9
M563 P0 S"Spindle" FOUT9 ; Define Tool 0 assign to OUT9 PWM (our Spindle)
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Custom settings are not defined
; CNC
M453 C"OUT9" R24000 F1000 ; Set to CNC mode, using Tool 0, 24000 Max RPM, 1khz -
@wikipedia_Brown said in GCode cancelling immediately:
(JocelynSign1)
G21
G90
(Engrave1)
G1 X66.037 Y-18.002 Z-2.270 F1000do you not have ";" in front of the comments:
; (JocelynSign1)
etc
I got it sorted. I was missing the WCS, and G55 commands.
