    Independent control of 2 drivers assigned to the same axis
    Gcode meta commands
    • RincewindBoi
      RincewindBoi last edited by
      I'm working on an MPCNC and was have 2 drivers assigned to the same axis that I want to home independently to square up the axis. I can't seem to find what GCode I should be calling to do so and was wondering how I should proceed. Any tips would be very much appreciated! Thank you.
      • jay_s_uk
        jay_s_uk last edited by
        This should work ok.
        https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors#Section_Axis_levelling_using_endstops
        Unless you need to offset one further than the other
        Owns various duet boards and is the main wiki maintainer for the Teamgloomy LPC/STM32F4 port of RRF
          In RRF3 that is easy to do by simply including both endstop pin names in the M574 command.
          example: M574 X1 P"xstop+e1stop" S1
          This would set the X axis to home to the low end, and use the xstop and e1stop endstop pins.
          • RincewindBoi
            Thanks all! Ill try it out.
