    BLTouch Homing in wrong direction
    3.6k
    • chrisundefined
      chris
      Hi When I use G30 it sends the BLTouch upwards instead of towards the build plate on my cartesian. I used G92 to allow me to move the axis without the machine being homed to confirm that they are not inverted and they run going the correct direction with the nozzle moving closer to the build platform with negative values.
      • chrisundefined
        chris
        Here is my config.g
        My Printer
        Send code...
        Status
        Idle
        Tool Position
        X
        0.0
        Y
        0.0
        Z
        0.00
        Extruder Drives
        Drive 0
        0.0
        Speeds
        Requested Speed
        0 mm/s
        Top Speed
        0 mm/s
        Sensors
        Vin
        22.1 V
        MCU Temperature
        32.5 C
        Fan RPM
        0
        Z-Probe
        0
        Tools
        Extra
        Control All
        Tool Heater Current Active Standby
        Extruder 1
        T0 - Load Filament n/a n/a
        0
        0
        Temperature Chart
        No Data
        System Directory
        0:/sys/config.g
        ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Sep 28 2020 10:10:20 GMT+0100 (British Summer Time)
        M550 P"My Printer" ; set printer name
        M552 S1 ; enable network
        M586 P0 S1 ; enable HTTP
        M586 P1 S0 ; disable FTP
        M586 P2 S1 ; enable Telnet
        M569 P0 S0 ; physical drive 0 goes backwards
        M569 P2 S0 ; physical drive 2 goes forwards
        M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
        M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
        M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
        M906 X1000 Y1000 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M208 X310 Y310 Z400 S0 ; set axis maxima
        M574 Z1 S2 ; configure Z-probe endstop for low end on Z
        M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5
        M558 P9 H5 F500 T4000 X0 Y0 Z1 ; Set Z probe to mode 9
        G31 P25 X46.5 Y0 Z0.0 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
        M557 X5:205 Y5:165 S20 ; Define mesh grid
        M140 H-1 ; disable heated bed (overrides default heater mapping)
        M308 S0 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin e0temp
        M950 H0 C"e0heat" T0 ; create nozzle heater output on e0heat and map it to sensor 0
        M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
        M106 P1 S1 H T45 ; set fan 1 value. Thermostatic control is turned on
        M563 P0 S"Extruder 1" D0 H1 F0 ; define tool 0
        • chrisundefined
          chris
          here is homez.g
          ; homez.g
          ; called to home the Z axis
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Sep 28 2020 10:10:21 GMT+0100 (British Summer Time)
          G91 ; relative positioning
          G90 ; absolute positioning
          G1 X15 Y15 F6000 ; go to first probe point
          ;G91 ; relative positioning
          ;G1 Z5 F100 ; lift Z relative to current position
          ;G90 ; absolute positioning
          • fcwiltundefined
            fcwilt
            In your G31 command you have the trigger height as Z=0.
            Is that correct?
              Are you sure your steps per mm on Z are correct at 400?
              What happens if you send G30 manually?
              You've posted homez, but what do you have in homeall?
              • chrisundefined
                chris
                hi here is home all, I am getting an error saying unable to reach point now.
                ; homeall.g
                ; called to home all axes
                G1 H1 X-315 Y-315 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                G1 H2 X5 Y5 F6000 ; go back a few mm
                G1 H1 X-315 Y-315 F360 ; move slowly to X and Y axis endstops once more (second pass)
                G1 X15 Y15 F6000 ; go to first bed probe point and home Z
                  Phaedrux Moderator @chris
                  @chris said in BLTouch Homing in wrong direction:
                  When are you getting that and what exactly does it say?
                  • chrisundefined
                    chris
                    cheers says,
                    Skipping grid point (40.0, 270.0) because Z probe cannot reach it
                    this is G31
                    G31 P25 X46.5 Y0 Z3.70
                      It can't reach point x40 because the probe is offset by 46.5
                      Alter your M557 grid points to account for the probes X offset.
                      M557 X50:205 Y5:165 S20 for example
                      • chrisundefined
                        chris
                        will try cheers
                        • chrisundefined
                          chris
                          issue I am having is saying G30 Probe zero not found
                            When are you getting that message?
                            What is in your config.g now? homeall.g?
                            • fcwiltundefined
                              fcwilt @chris
                              As I understand it when trying to probe the point where Z=40 you got the error message about the probe not reaching it.
                              Then you changed M557 to use X50:205.
                              And you made no other changes?
                                In you rother thread you just updated to 3.1.1, did you also get a new config set?
                                • chrisundefined
                                  chris
                                  yeah updated here is my new config .g
                                  M92 X80.00 Y80.00 Z400.00 E415 ; set steps per mm
                                  M566 X720.00 Y720.00 Z18.00 E600.00 ; set maximum instantaneous speed changes (mm/min)
                                  M203 X6000.00 Y6000.00 Z180.00 E3000.00 ; set maximum speeds (mm/min)
                                  M201 X750 Y750 Z100 E5000 ; set accelerations (mm/s^2)
                                  M906 X1000 Y1000 Z800 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
                                  M208 X305 Y330 Z400 S0 ; set axis maxima
                                  M574 Z1 S2 ; Define Z to use Probe. Home to Min
                                  M558 P9 H5 F500 T4000 X0 Y0 Z1 ; Set Z probe type/mode 5. H=Dive Height. F=Speed the bed moves
                                  G31 P25 X46.5 Y0 Z3.70 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
                                  M557 X50:280 Y45:310 S50 ; define mesh grid
                                  M308 S0 P"bedtemp" Y"Thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp
                                  M950 F0 C"fan0" Q500 ; create fan 0 on pin fan 0
                                  M106 P0 S1 H1 T60 ; enable thermostatic control on fan 0 heater 1 sensor 1
                                  M950 F1 C"fan1" Q500 ; create fan 1 on pin fan 1
                                  M106 P1 S0 H-1 ; disable thermostatic control on fan 1
                                  ; Automatic power saving
                                  M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                                  ; Default firmware retraction configuration
                                  M207 S3.2 R-0.1 F3600 T1200 Z0 ; Set 3.2mm retraction, -0.1 restart, 3600 mm/min feed rate, 1200 mm/min restart feed rate, no z change
                                  ; Other settings
                                  G29 S1 ; Enable automatic bed mesh compensation
                                  M572 D0 S0.16 ; Enable pressure-advance
                                  M915 X Y S10 F1 R1 ; Enable stall detection for X and Y axis with a sensitivity of 10 and report only
                                  M915 Z S0 F1 R1 ; Enable stall detection for Z axis with a sensitivity of 10 and report only
                                    Don't put this in config.g because it will load the heightmap before you have even homed the printer. A better place to put it is in your slicer start gcode after you've done a G28 to home all axis.
                                    The zprobe section is still formatted for RRF2. In RRF3 you should have something more like this:
                                    M950 S0 C"exp.heater7"                         ; create servo pin 0 for BLTouch
                                    M558 P9 C"^zprobe.in" H5 F120 T6000           ; set Z probe type to bltouch and the dive height + speeds
                                    G31 P25 X46.5 Y0 Z3.6                         ; set Z probe trigger value, offset and trigger height
                                    ; deployprobe.g
                                    ; called to deploy a physical Z probe
                                    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 30 2020 15:12:19 GMT-0600 (Central Standard Time)
                                    M280 P0 S10 ; deploy BLTouch
                                    ; retractprobe.g
                                    ; called to retract a physical Z probe
                                    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 30 2020 15:12:33 GMT-0600 (Central Standard Time)
                                    M280 P0 S90 ; retract BLTouch
                                    • chrisundefined
                                      chris
                                      getting this error now
                                      G28 Warning: Obsolete use of S parameter on G1 command. Use H parameter instead.
                                        It looks like you didn't take the full config file set from the configurator as suggested in your other thread. It would have made all the changes needed for RRF3.
                                        That warning is telling you that your homing files are using G1 S1 and G1 S2 and the S should be changed to H. (G1 S is now used for laser power when in laser mode)
                                        ; homeall.g
                                        ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 30 2020 15:29:23 GMT-0600 (Central Standard Time)
                                        G1 H1 X-235 Y-215 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                                        G1 H1 X-235 Y-215 F360  ; move slowly to X and Y axis endstops once more (second pass)
                                        G1 X-31.5 Y15 F6000     ; go to first bed probe point and home Z
                                        • chrisundefined
                                          chris
                                          Used reprap firmware config tool tool to create new config .g file but now bltouch isn't deploying it does self test fine on powering up the printer but doesn't deploy with M280 P0 Z10.
                                          here is my new config .g now
                                          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Oct 01 2020 12:28:30 GMT+0100 (British Summer Time)
                                          M550 P"Creality CR-10" ; set printer name
                                          M586 P2 S0 ; disable Telnet
                                          M92 X80.00 Y80.00 Z400.00 E415.00 ; set steps per mm
                                          M203 X60000.00 Y60000.00 Z30000.00 E1200.00 ; set maximum speeds (mm/min)
                                          M208 X310 Y320 Z400 S0 ; set axis maxima
                                          G31 P500 X0 Y0 Z3.7 ; set Z probe trigger value, offset and trigger height
                                          M557 X50:280 Y50:280 S50 ; define mesh grid
                                          M106 P0 S0 H1 T60 ; set fan 0 value. Thermostatic control is turned on
                                          M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
                                          • chrisundefined
                                            chris
                                            here is home z
                                            ; homez.g
                                            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Oct 01 2020 12:28:31 GMT+0100 (British Summer Time)
                                            G1 X50 Y50 F6000 ; go to first probe point
