    BLTouch Homing in wrong direction
    3.6k
    • chrisundefined
      chris
      will try cheers
      • chrisundefined
        chris
        issue I am having is saying G30 Probe zero not found
          When are you getting that message?
          What is in your config.g now? homeall.g?
          • fcwiltundefined
            fcwilt @chris
            @chris said in BLTouch Homing in wrong direction:
            As I understand it when trying to probe the point where Z=40 you got the error message about the probe not reaching it.
            Then you changed M557 to use X50:205.
            And you made no other changes?
              In you rother thread you just updated to 3.1.1, did you also get a new config set?
              • chrisundefined
                chris
                yeah updated here is my new config .g
                ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Sep 28 2020 10:10:20 GMT+0100 (British Summer Time)
                M550 P"My Printer" ; set printer name
                M552 S1 ; enable network
                M586 P0 S1 ; enable HTTP
                M586 P1 S0 ; disable FTP
                M586 P2 S1 ; enable Telnet
                M569 P0 S0 ; physical drive 0 goes backwards
                M92 X80.00 Y80.00 Z400.00 E415 ; set steps per mm
                M566 X720.00 Y720.00 Z18.00 E600.00 ; set maximum instantaneous speed changes (mm/min)
                M203 X6000.00 Y6000.00 Z180.00 E3000.00 ; set maximum speeds (mm/min)
                M201 X750 Y750 Z100 E5000 ; set accelerations (mm/s^2)
                M906 X1000 Y1000 Z800 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                M208 X305 Y330 Z400 S0 ; set axis maxima
                M574 Z1 S2 ; Define Z to use Probe. Home to Min
                M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5
                M558 P9 H5 F500 T4000 X0 Y0 Z1 ; Set Z probe type/mode 5. H=Dive Height. F=Speed the bed moves
                G31 P25 X46.5 Y0 Z3.70 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
                M557 X50:280 Y45:310 S50 ; define mesh grid
                M308 S0 P"bedtemp" Y"Thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp
                M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                M950 F0 C"fan0" Q500 ; create fan 0 on pin fan 0
                M106 P0 S1 H1 T60 ; enable thermostatic control on fan 0 heater 1 sensor 1
                M950 F1 C"fan1" Q500 ; create fan 1 on pin fan 1
                M106 P1 S0 H-1 ; disable thermostatic control on fan 1
                ; Automatic power saving
                M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                ; Default firmware retraction configuration
                M207 S3.2 R-0.1 F3600 T1200 Z0 ; Set 3.2mm retraction, -0.1 restart, 3600 mm/min feed rate, 1200 mm/min restart feed rate, no z change
                ; Other settings
                G29 S1 ; Enable automatic bed mesh compensation
                M572 D0 S0.16 ; Enable pressure-advance
                M915 X Y S10 F1 R1 ; Enable stall detection for X and Y axis with a sensitivity of 10 and report only
                M915 Z S0 F1 R1 ; Enable stall detection for Z axis with a sensitivity of 10 and report only
                M501 ; Load saved parameters from non-volatile memory
                  Phaedrux Moderator @chris
                  Don't put this in config.g because it will load the heightmap before you have even homed the printer. A better place to put it is in your slicer start gcode after you've done a G28 to home all axis.
                  The zprobe section is still formatted for RRF2. In RRF3 you should have something more like this:
                  M950 S0 C"exp.heater7"                         ; create servo pin 0 for BLTouch
                  M558 P9 C"^zprobe.in" H5 F120 T6000           ; set Z probe type to bltouch and the dive height + speeds
                  G31 P25 X46.5 Y0 Z3.6                         ; set Z probe trigger value, offset and trigger height
                  ; deployprobe.g
                  ; called to deploy a physical Z probe
                  ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 30 2020 15:12:19 GMT-0600 (Central Standard Time)
                  M280 P0 S10 ; deploy BLTouch
                  ; retractprobe.g
                  ; called to retract a physical Z probe
                  ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 30 2020 15:12:33 GMT-0600 (Central Standard Time)
                  M280 P0 S90 ; retract BLTouch
                  • chrisundefined
                    chris
                    getting this error now
                    G28 Warning: Obsolete use of S parameter on G1 command. Use H parameter instead.
                      It looks like you didn't take the full config file set from the configurator as suggested in your other thread. It would have made all the changes needed for RRF3.
                      That warning is telling you that your homing files are using G1 S1 and G1 S2 and the S should be changed to H. (G1 S is now used for laser power when in laser mode)
                      ; homeall.g
                      ; called to home all axes
                      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 30 2020 15:29:23 GMT-0600 (Central Standard Time)
                      G1 H2 Z5 F6000          ; lift Z relative to current position
                      G1 H1 X-235 Y-215 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                      G1 H2 X5 Y5 F6000       ; go back a few mm
                      G1 H1 X-235 Y-215 F360  ; move slowly to X and Y axis endstops once more (second pass)
                      G90                     ; absolute positioning
                      G1 X-31.5 Y15 F6000     ; go to first bed probe point and home Z
                      G30                     ; home Z by probing the bed
                      • chrisundefined
                        chris
                        Used reprap firmware config tool tool to create new config .g file but now bltouch isn't deploying it does self test fine on powering up the printer but doesn't deploy with M280 P0 Z10.
                        here is my new config .g now
                        ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Oct 01 2020 12:28:30 GMT+0100 (British Summer Time)
                        M550 P"Creality CR-10" ; set printer name
                        M586 P2 S0 ; disable Telnet
                        M569 P2 S0 ; physical drive 2 goes backwards
                        M92 X80.00 Y80.00 Z400.00 E415.00 ; set steps per mm
                        M203 X60000.00 Y60000.00 Z30000.00 E1200.00 ; set maximum speeds (mm/min)
                        M906 X1000 Y1000 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
                        M208 X310 Y320 Z400 S0 ; set axis maxima
                        G31 P500 X0 Y0 Z3.7 ; set Z probe trigger value, offset and trigger height
                        M557 X50:280 Y50:280 S50 ; define mesh grid
                        M106 P0 S0 H1 T60 ; set fan 0 value. Thermostatic control is turned on
                        M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
                        M563 P0 S"Extruder 1" D0 H1 F0 ; define tool 0
                        • chrisundefined
                          chris
                          here is home z
                          ; homez.g
                          ; called to home the Z axis
                          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Oct 01 2020 12:28:31 GMT+0100 (British Summer Time)
                          G1 X50 Y50 F6000 ; go to first probe point
                          ;G91 ; relative positioning
                          ;G90 ; absolute positioning
                          • fcwiltundefined
                            fcwilt
                            G31 P500 X0 Y0 Z3.7
                            In your config.g file there is this line related to the Z probe.
                            Being a BLTouch the P parameter should be 25.
                            And I cannot image how the X and Y offsets could be 0. Those values are saying that the BLTouch pin is right where the nozzle is, along the X and Y axes.
                            As to the probe self-testing but not working you need to verify that the wiring is correct. It's getting power but it seems it may not be getting the control signal.
                            chrisundefined 1 Reply Last reply Reply Quote 0
                              Replace your zprobe section and deploy and retract macros with the ones I posted above. I took your values from your original config and brought them forward. The one you just generated doesn't have that.
                              Was the deploy and retract working before?
                              M280 P0 Z10.
                              That should be S10 not Z10
                              • chrisundefined
                                chris
                                yeah before I upgraded to v 3.1.1 yeah sorry was M280 P0 S10
                                • chrisundefined
                                  chris @fcwilt
                                  @fcwilt Sorry this was g31
                                  G31 P50 X46.5 Y0 Z3.7 ; set Z probe trigger value, offset and trigger height
                                  • chrisundefined
                                    chris
                                    This post is deleted!
                                    • chrisundefined
                                      chris @Phaedrux
                                      @Phaedrux yeah still no joy with G31 S-1 or M280 P0 S10. even when copied config u posted above using bltouch on heater 7 pwm on duet expansion breakout board. Obviously is wired correctly as does self test fine when power applied to the printer. Just not deploying.
                                      fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                      • fcwiltundefined
                                        fcwilt @chris
                                        Those values look reasonable. But I believe that P50 should be P25.
                                        • chrisundefined
                                          chris @fcwilt
                                          @fcwilt Wouldn't have thought that would have stopped it deploying though isn't that just trigger value?
                                          • fcwiltundefined
                                            fcwilt @chris
                                            Self test only requires that the power and ground connections be correct.
                                            If the control signal from the duet that triggers the probe deployment doesn't get to the probe then it won't work.
                                            So either the configuration of the Z probe doesn't match the pin you are using to trigger the probe OR something has happened to the wiring .
