    RRF 3.2 Beta 1: pause.g not executed on M600
    Beta Firmware
    • docbobo
      docbobo last edited by
      I am running RR3 3.2 beta 1 on a BTT SKR 1.4 Turbo with SBC
      DSF Version 3.2.0-beta1+1
      DWC Version 3.2.0-beta1+2
      I was just trying out some filament change during print, and according to documentation, M600 should execute pause.g if no filament-change.g is present. In my case though, just the extruder stopped moving. It did not execute the pause.g code.
      Copying pause.g to filament-change.g resulted in the correct behavior in that regard, but it certainly doesn't match the documentation.
      Here's my M122
      RepRapFirmware for LPC176x based Boards (biquskr_1.4) version 3.2-beta1_2 running on LPC176x at 120Mhz
      Used output buffers: 1 of 16 (12 max)
      Static ram: 4704
      Dynamic Memory (RTOS Heap 5): 1960 free, 1936 never used
      Exception stack ram used: 448
      Never used ram: 60
      Tasks: HEAT(blocked,338) MAIN(running,326) IDLE(ready,20)
      Owned mutexes:
      Last reset 02:19:16 ago, cause: [power up]
      Last software reset at 2020-09-30 20:19, reason: User, LinuxInterface spinning, available RAM 268, slot 2
      Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0440f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
      Error status: 0x020
      Supply voltage: under voltage events: 0
      Driver 0: position 13616,  standstill, SG min/max 130/130, error r/w 0/0, ifcnt 87, cnt r/w 506/0, timeout 0, failedOp 0xff
      Driver 1: position 9670,  standstill, SG min/max 158/158, error r/w 0/0, ifcnt 87, cnt r/w 506/0, timeout 0, failedOp 0xff
      Driver 2: position 22080,  standstill, SG min/max 40/40, error r/w 0/0, ifcnt 74, cnt r/w 505/0, timeout 0, failedOp 0xff
      Driver 3: position 0,  standstill, SG min/max 2/2, error r/w 0/0, ifcnt 50, cnt r/w 505/0, timeout 0, failedOp 0xff
      Driver 4: position 0,  standstill, SG min/max 14/14, error r/w 0/0, ifcnt 74, cnt r/w 505/0, timeout 0, failedOp 0xff
      Driver 5: position 0
      Driver 6: position 0
      Date/time: 2020-10-01 12:25:05
      Slowest loop: 3.93ms; fastest: 0.31ms
      Step timer: target 3636317556 count 4051167559 delta -414850003 late 0
      USBSerial connected 1
      ADC not ready 0 ADC error threshold 10 ADC Init 1
      Ints: 5646; Calls 7528; fast: 2uS; slow 12uS adj 63 bad 0 big delta 0
      PWM Channels
      state 0 next 40614 on 55770 off 64230 pin 2.5
      state 1 next 40614 on 52380 off 67620 pin 2.7
      Delta 40614 Start 0 End 2
      Hiccups: 0, FreeDm: 100, MinFreeDm: 100, MaxWait: 0ms
      === DDARing ===
      Scheduled moves: 595, completed moves: 595, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
      Bed heaters = 0, chamberHeaters = -1
      Heater 0 is on, I-accum = 0.5
      Heater 1 is on, I-accum = 0.4
      Segments left: 0
      Movement lock held by null
      HTTP* is ready with "M122" in state(s) 0
      Telnet is idle in state(s) 0
      File* is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue* is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon* is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Filament sensors ===
      Extruder 0 sensor: ok
      === SBC interface ===
      State: 0, failed transfers: 0
      Last transfer: 14ms ago
      RX/TX seq numbers: 24229/4160
      SPI underruns 0, overruns 0
      Number of disconnects: 0
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v3.2.0-beta1+1
      Code buffer space: 2048
      Configured SPI speed: 8000000 Hz
      Full transfers per second: 29.74
        Thanks for the report.
        @chrishamm
        chrishamm 1 Reply Last reply Reply Quote 0
        • chrishamm
          chrishamm administrators @Phaedrux last edited by
          @Phaedrux @docbobo This will be fixed in the upcoming version 3.2-b2.
          Duet software engineer
