    Hotend breakout board
    • ericlmccormick
      ericlmccormick last edited by
      I know the duet boards are designed to work with many different setups but many people use them for 3D printing. One of my biggest hassles is running all with wiring from my hotend back to the board. I would be nice it there was a variant that instead of placing everything on a single board, you had the components that go with a hotend on a breakout board. Then you would buy the main board and then add a breakout board to go along with each hotend you have. Then you would have a single ribbon cable that you could cut to length and have a clean setup.
      The main board would consist of
      X, Y, Z1 Z2 steppers (4pin)
      X, Y, Z1 Z2 end stops (3 pin)
      H0 Heater (2 pin)
      H0 Thermocouple (2pin)
      Case fan(3 pin)
      4 or more breakout headers
      Breakout board would have
      ExStepper - 4Pin
      ExHeater - 2Pin
      ExTemp - 2Pin
      X and Y Sensor(redundant) - 3Pin
      ZSensor - 3Pin
      PartFan - 2Pin
      HeaterFan - 2Pin
      AUX5/12/24
        There's no need to multipost.
        https://forum.duet3d.com/topic/18999/duet-with-hotend-breakout-boards?_=1601660489522
