    Software reset whilst printing in SBC mode - Beta 3.2-1
    Hardware dev
    • jay_s_uk
      jay_s_uk last edited by jay_s_uk
      Printing for the first time with the mini 5+ with an SBC attached. This is mainly due to the issue with the internal SD card.
      I suffered a reset. Below is the M122 output.
      RepRapFirmware for Duet 3 Mini 5+ version 3.2-beta1 running on Duet 3 Mini5plus WiFi (SBC mode)
      Board ID: 8ULVP-1D6P9-F65J0-401FQ-2A03Z-RJW1V
      Used output buffers: 1 of 40 (10 max)
      Static ram: 85692
      Dynamic ram: 105584 of which 44 recycled
      Exception stack ram used: 224
      Never used ram: 70600
      Tasks: HEAT(blocked,321) TMC(blocked,63) MAIN(running,557) IDLE(ready,20) AIN(blocked,267)
      Owned mutexes:
      Last reset 00:36:40 ago, cause: software
      Last software reset at 2020-10-02 20:19, reason: StuckInSpinLoop, GCodes spinning, available RAM 69708, slot 2
      Software reset code 0x4083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f80f BFAR 0xe000ed38 SP 0x20007954 Task MAIN
      Stack: 00000940 0002e412 010f0000 3f800000 401c0000 3edb6db7 b6376c00 3e4c6bb0 b202d445 44fa76c6 44fa76c6 00000000 447a76c6 447a76c6 3e4c6bb1 3ca38959 3bb9135a 3f800000 3f800000 20000011 a5a5a5a5 2001a710 2001c448 91752604 a5a5a5a5 a5a5a5a5 a5a5a5a5
      Error status: 0x020
      Supply voltage: min 0.0, current 12.6, max 12.6, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 0, standstill, read errors 0, write errors 1, ifcnt 17, reads 52032, writes 10, timeouts 0, DMA errors 0
      Driver 1: position 0, standstill, read errors 0, write errors 1, ifcnt 17, reads 51224, writes 10, timeouts 808, DMA errors 0, failedOp 0x06
      Driver 2: position 0, standstill, read errors 0, write errors 1, ifcnt 17, reads 52006, writes 10, timeouts 26, DMA errors 0, failedOp 0x6f
      Driver 3: position 0, standstill, read errors 0, write errors 1, ifcnt 17, reads 52031, writes 10, timeouts 0, DMA errors 0
      Driver 4: position 0, standstill, read errors 0, write errors 1, ifcnt 13, reads 52032, writes 10, timeouts 0, DMA errors 0
      Driver 5: position 0, assumed not present
      Driver 6: position 0, assumed not present
      Driver 7: position 0, assumed not present
      Date/time: 2020-10-02 20:56:57
      Slowest loop: 2.89ms; fastest: 0.08ms
      === Storage ===
      Free file entries: 10
      SD card 0 not detected, interface speed: 11.2MBytes/sec
      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
      === MainDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
      === AuxDDARing ===
      Bed heaters = 0 -1, chamberHeaters = -1 -1
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP* is ready with "M122" in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon* is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 0.00ms; fastest: 5726623.00ms
      Responder states:
      HTTP sessions: 0 of 8
      - WiFi -
      Network state is disabled
      WiFi module is disabled
      Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485
      === SBC interface ===
      State: 0, failed transfers: 0
      Last transfer: 11ms ago
      RX/TX seq numbers: 42795/4463
      SPI underruns 0, overruns 0
      Number of disconnects: 0
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v3.2.0-beta1+1
      Code buffer space: 4096
      Configured SPI speed: 8000000 Hz
      Full transfers per second: 31.68
      Edit: I'm using the ribbon cable from my duet 3
      Owns various duet boards and is the main wiki maintainer for the Teamgloomy LPC/STM32F4 port of RRF
      • jay_s_uk
        I removed daemon.g and was able to get through a print.
        Here are the contents of it.
        if {state.status == "idle"}
        	M42 P0 S0
        else
        	M42 P0 S1
          I've put a new build with improved (I hope) SD card error recovery at https://www.dropbox.com/s/4mtjx1oo73nwv69/Duet3Firmware_Mini5plus_v02.uf2?dl=0. Please try it carefully. Currently I work with the version 0.4 prototype, and I test the build for the version 0.2 prototype only occasionally.
          • jay_s_uk
            I've installed this build and it no longer connect in SBC mode.
            I'll move the sd card and try it in standalone
            chrishamm 1 Reply Last reply Reply Quote 0
            • chrishamm
              chrishamm administrators @jay_s_uk last edited by
              @jay_s_uk The latest RRF version requires DSF 3.2-b2 because the SPI protocol has slightly changed. I hope we can release that on Monday.
              Duet software engineer
              jay_s_uk 1 Reply Last reply Reply Quote 0
              • jay_s_uk
                jay_s_uk @chrishamm last edited by
                @chrishamm thanks for letting me know. I'll move to standalone and then test again when the next beta is released
