    Belt Bed Machine support
    Firmware wishlist
    • Adamfilipundefined
      Adamfilip
      I am interested in building a 3d Printer with a Belt Bed, there XY is on a 45 degree angle.
      not sure what would be needed for the Duet to support this type of machine if anything.
      https://printrbot.com/shop/printrbelt/
      • T3P3Tonyundefined
        T3P3Tony administrators
        Yeah pretty cool machine, (and also the blackbelt). Do you know if they are handling this in the slicer or the firmware? I ask because watching videos of how it works it would appear it would need to be sliced in a certain way to deal with laying down layers at a 45 degree angle.
        I suppose the slicer could rotate the model by 45 degrees so that each layer was oriented correctly, at that point is it not a Cartesian machine?
        www.duet3d.com
          Looks to me that it can be handled entirely in firmware as a variant of CoreXZ kinematics. The existing CoreXZ kinematics may even handle it already because it allows you to adjust the X and Z scale factors.
            Adamfilip
            I heard the gcode was post processed to offset everything. also i saw a post about a modified version of cura, but i cant find it again lol.
            • Whitewolfundefined
              Whitewolf
              Here is a similar design that uses a carbon fiber belt.
              https://www.kickstarter.com/projects/814534542/blackbelt-3d-printer
              Exploring the universe wherever the tech blows
