    Solved Duet 3 rrf 3.2.x + SBC No reserrect.g file is written.
    Beta Firmware
    • MartenPothoven
      MartenPothoven last edited by
      (Duet 3 rrf 3.2.x + SBC) No reserrect.g file is written when pause is pressed.
      But same Duet 3 board in stand alone mode with same config.g, everything works fine.
      Power loss M911 also does not work with sbc but it does works fine in stand alone mode.
      Has it to do with sudo rights (permissions) on the Raspberry Pi ????? HELP
        Hi, I believe that is a currently known issue.
        https://github.com/Duet3D/DuetSoftwareFramework/issues/55
        wilriker created this issue in Duet3D/DuetSoftwareFramework
        closed Auto save on loss of power not working #55
        • MartenPothoven
          @MartenPothoven said in Duet 3 rrf 3.2.x + SBC No reserrect.g file is written.:
          Phaedrux ,
          issues/55 has to do with a power issue I believe,
          (the voltage on the RPi drops so fast that there is no time to write the resurrect.g)
          But in this case when I press the Pause Button in the DWC, no resurrect.g file is written at all.
          On Duet 2 WiFi rrf 3.1.1 its works fine.
          On Duet 3 MB6HC 3.2-beta1+ 3HC in stand alone mode its works fine.
          But on Duet 3 MB6HC 3.2-beta1 with SBC (RPi). Pause (M25) does not work. When I send a M25 (Pause) the nozzle goes to X0 Y0, and when I send a M24 (Resume) the nozzle goes to the old coordinates and the printing stops (Print job is finished). ???
          ; resume.g
          ; called before a print from SD card is resumed
          G1 R1 X0 Y0 Z5 F6000 ; go to 5mm above position of the last print move
          G1 R1 X0 Y0 ; go back to the last print move
          M83 ; relative extruder moves
          G1 E10 F3600 ; extrude 10mm of filament
          ; pause.g
          ; called when a print from SD card is paused
          G1 E-10 F3600 ; retract 10mm of filament
          G91 ; relative positioning
          G1 Z5 F360 ; lift Z by 5mm
          G90 ; absolute positioning
          G1 X0 Y0 F6000 ; go to X=0 Y=0
          • jay_s_uk
            jay_s_uk last edited by
            the pause issue has been fixed in 3.2-beta 2 i believe
            • MartenPothoven
              Yes, after updating 3.2-beta 2 the pause issue is SOLVED.
