    trouble with homing the x and y axes on a core xy printer.
    1.8k
    • campeancalinundefined
      campeancalin
      Hello all.
      I am currently working on a Core XY setup for which the decision was made that a duet WIFI paired with a Duex5 should be used for the brains. RRF configurator was a usefull tool to generate the first configuration for the machine(RRF3.1.1 and DWC 3.1.1). However, once I achieved the right orientation for the xy gantry, by testing the "G91 /G1 H2 X10 F3000", and the "G91/ G1 H2 Y10 F3000" , and decided to go further with the attempt to home the xy gantry to no avail. The A and B motors are "stiff"( if I try to rotate them by hand , I cant), as if one would try to turn opposed to the other.
      The config.g settings look like this:
       Drives
      M569 P0 S0                                         ; physical drive 0 goes backwards
      M569 P1 S0                                         ; physical drive 1 goes backwards
      M569 P2 S1                                         ; physical drive 2 goes FORWARDS
      M569 P3 S1                                         ; physical drive 3 goes FORWARDS
      M569 P4 S0                                         ; physical drive 4 goes backwards
      M569 P5 S0                                         ; physical drive 5 goes backwards
      M584 X1 Y0 Z2:3 E4:5                               ; set drive mapping; INIT:X=0; Y=1; Z2;E3:4
      M350 X16 Y16 Z16:16 E16:16 I1                     	   ; configure microstepping with interpolation ; INIT- M350 X16 Y16 Z16 E16:16 I1
      M92 X160.00 Y160.00 Z3200.00:3200.00 E420.00:420.00        ; set steps per mm
      M566 X900.00 Y900.00 Z12.00:12.00 E120.00:120.00           ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00:180.00 E1200.00:1200.00     ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00:20.00 E250.00:250.00           ; set accelerations (mm/s^2)
      M906 X1400 Y1400 Z1200:1200 E800:800 I80                   ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                    ; Set idle timeout
      M208 X500 Y500 Z500 S0                             ; set axis maxima
      M574 X1 S1 P"xstop"                                ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                                ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
      Bellow are the home*.g files:
      ; homex.g
      ; called to home the X axis
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Oct 05 2020 11:50:09 GMT+0300 (Eastern European Summer Time)
      G91                ; relative positioning
      G1 H2 Z5 F200      ; lift Z relative to current position
      G1 H1 X-505 F1800  ; move quickly to X axis endstop and stop there (first pass)
      G1 X5 F600         ; go back a few mm
      G1 H1 X-5 F360     ; move slowly to X axis endstop once more (second pass)
      G1 H2 Z-5 F6000    ; lower Z again
      G90                ; absolute positioning
      ; homey.g
      ; called to home the Y axis
      G1 H1 Y-505 F1800  ; move quickly to Y axis endstop and stop there (first pass)
      G1 Y5 F600         ; go back a few mm
      G1 H1 Y-5 F360     ; move slowly to Y axis endstop once more (second pass)
      ; homez.g
      ; called to home the Z axis
      G1 H2 Z5 F800  ; lift Z relative to current position
      G1 X15 Y15 F2400 ; go to first probe point
      G30            ; home Z by probing the bed
      G1 Z2 F100    ; lift Z relative to current position
      ; homeall.g
      ; called to home all axes
      M98 P"homex.g"
      M98 P"homey.g"
      M98 P"homez.g"
      Any help , sugestion, advice will be very appreciated
      Edit: Formatting
      • Vetiundefined
        Veti
        you did not post you entire config.
        its unclear if you enabled corexy mode.
          campeancalin
          Here you go:
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Oct 05 2020 11:50:08 GMT+0300 (Eastern European Summer Time)
          M550 P"Oscar"                                      ; set printer name
          M669 K1                                            ; select CoreXY mode
          M551 P""                                           ; set password
          M586 P1 S1                                         ; enable FTP
          M950 S0 C"duex.e5heat"                             ; create servo pin 0 for BLTouch
          M558 P9 C"^zprobe.in" H5 F120 T6000                ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X10 Y10 Z3.5                              ; set Z probe trigger value, offset and trigger height
          M557 X15:470 Y15:470 S20                           ; define mesh grid
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
          M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
          M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
          M308 S2 P"e1temp" Y"thermistor" T100000 B4138      ; configure sensor 2 as thermistor on pin e1temp
          M950 H2 C"e1heat" T2                               ; create nozzle heater output on e1heat and map it to sensor 2
          M307 H2 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
          M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
          M106 P0 S1 H-1                                     ; set fan 0 value. Thermostatic control is turned off
          M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
          M106 P1 S1 H-1                                     ; set fan 1 value. Thermostatic control is turned off
          M563 P0 S"Tool 1" D0 H1 F0                         ; define tool 0
          M563 P1 S"Tool 2" D1 H2 F0                         ; define tool 1
          G10 P1 X0 Y0 Z0                                    ; set tool 1 axis offsets
          G10 P1 R0 S0                                       ; set initial tool 1 active and standby temperatures to 0C
          M575 P1 S1 B57600                                  ; enable support for PanelDue
          M501                                               ; load saved parameters from non-volatile memory
          Edit: formatting
          • Vetiundefined
            Veti
            @campeancalin said in trouble with homing the x and y axes on a core xy printer.:
            if this moves only in the X direction, then you do not have a corexy machine
            what do you mean by that? there was no movement?
            the homing code does the same thing as your manual move in the first command.
            please post the output of m122
            campeancalinundefined 1 Reply Last reply Reply Quote 0
            • fcwiltundefined
              fcwilt
              In you config.g file you have this:
              As I recall for a BLTouch P500 should be P25
              And are you sure those X10 and Y10 offset values are correct?
              I designed my own hotend mount and the closest I could position the BLTouch was X0 Y25.
              Also for testing you can use M564 to allow using the DWC jog buttons before homing as been done.
              The possible parameters to M564 are H and/or S (see below):
              H1 = forbid movement of axes that have not been homed, H0 = allow movement of axes that have not been homed
              S1 = limit movement within axis boundaries, S0 = allow movement outside boundaries
              So issuing M564 H0 would allow using the jog buttons, M564 H1 would restore things to normal.
                campeancalin @Veti
                @Veti said in trouble with homing the x and y axes on a core xy printer.:
                m122
                Bellow you have the M122 result:
                M122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later + DueX5
                Board ID: 08DGM-917NK-F23T0-6JKFG-3S46S-1HAJF
                Used output buffers: 3 of 24 (9 max)
                Static ram: 25680
                Dynamic ram: 94376 of which 188 recycled
                Exception stack ram used: 320
                Never used ram: 10508
                Tasks: NETWORK(ready,652) HEAT(blocked,1236) DUEX(suspended,156) MAIN(running,3748) IDLE(ready,160)
                Owned mutexes:
                Last reset 00:03:17 ago, cause: power up
                Last software reset at 2020-10-05 16:45, reason: User, spinning module GCodes, available RAM 10480 bytes (slot 3)
                Error status: 0
                Free file entries: 10
                MCU temperature: min 25.7, current 32.5, max 32.5
                Supply voltage: min 23.8, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                Driver 5: standstill, SG min/max not available
                Driver 6: standstill, SG min/max not available
                Driver 7: standstill, SG min/max not available
                Driver 8: standstill, SG min/max not available
                Driver 9: standstill, SG min/max not available
                Date/time: 2020-10-05 19:51:00
                Cache data hit count 763106029
                Slowest loop: 2.24ms; fastest: 0.07ms
                Hiccups: 0, FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                === DDARing ===
                Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                Segments left: 0
                Movement lock held by null
                http is idle in state(s) 0
                telnet is idle in state(s) 0
                file is idle in state(s) 0
                serial is idle in state(s) 0
                aux is idle in state(s) 0
                daemon is idle in state(s) 0
                queue is idle in state(s) 0
                Code queue is empty.
                === Network ===
                Slowest loop: 41.62ms; fastest: 0.00ms
                HTTP sessions: 1 of 8
                - WiFi -
                Network state is running
                WiFi firmware version 1.23
                WiFi MAC address ec:fa:bc:02:17:e5
                WiFi Vcc 3.42, reset reason Turned on by main processor
                WiFi flash size 4194304, free heap 25448
                WiFi IP address 192.168.0.100
                WiFi signal strength -61dBm, reconnections 0, sleep mode modem
                Edit: formatting
                • Vetiundefined
                  Veti
                  there is your problem. you are not on RRF3.1.1 as you have written
                  campeancalinundefined 1 Reply Last reply Reply Quote 1
                    campeancalin @Veti
                    ok, I might have confused it with the config tool version.
                      campeancalin @fcwilt
                      @fcwilt do these commands work if the version of the firmware is 2.03?
                      Vetiundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                      • Vetiundefined
                        Veti @campeancalin
                        @campeancalin
                        your config file does not work with RRF2
                          campeancalin @Veti
                          @Veti Can you be a bit more specific?
                          Vetiundefined 1 Reply Last reply Reply Quote 0
                          • Vetiundefined
                            Veti @campeancalin
                            @campeancalin
                            the pin configuration syntax only works in rrf3
                            • fcwiltundefined
                              fcwilt @campeancalin
                              Yes they do.
                              But a set of files generated for v3 firmware will not work with v2 firmware without some changes.
                              I would go ahead and update the firmware to v3.
                              First update using Duet2and3Firmware-3.0.zip.
                              When asked allow it to update.
                              Then update using Duet2and3Firmware-3.1.1.zip
                              You can upload each ZIP file on the System page.
                                Once you update to 3.1.1 your current config has a better chance of working.
                                You should probably redo the motor direction tests for corexy after you update.
                                https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Testing_motor_movement
                                  campeancalin
                                  Thank you kindly. I was not aware of these differences
                                    Since you're starting from scratch it doesn't much matter, but here are the details.
                                    https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
                                      campeancalin
                                      Hello guys,
                                      Thank you again for the heads up regarding the differencies between the machine config and the firmware that was on the board.
                                      Today I went on and upgraded the firmware on the board, and reuploaded the machine config. At a first glance, the xy gantry seems to move in the right direction ; I still cant perform the homing on them. I also moved the z axis, on which I have 2 in series motors ( ZA and ZB are being used to control them), and while the z axis is performing the required movement , the E0 extruder motor is also moving.
                                      Bellow you can see the M122 report:
                                      M122
                                      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later + DueX5
                                      Used output buffers: 3 of 24 (11 max)
                                      Static ram: 27980
                                      Dynamic ram: 94972 of which 20 recycled
                                      Exception stack ram used: 408
                                      Never used ram: 7692
                                      Tasks: NETWORK(ready,292) HEAT(blocked,1224) DUEX(suspended,160) MAIN(running,1824) IDLE(ready,80)
                                      Owned mutexes: WiFi(NETWORK)
                                      Last reset 00:10:43 ago, cause: software
                                      Last software reset at 2020-10-06 17:51, reason: User, spinning module GCodes, available RAM 7700 bytes (slot 1)
                                      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                                      Error status: 0
                                      MCU temperature: min 32.7, current 33.3, max 34.0
                                      Supply voltage: min 23.8, current 24.0, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                                      Driver 2: standstill, SG min/max 0/260
                                      Driver 3: standstill, SG min/max 0/51
                                      Date/time: 2020-10-06 18:02:09
                                      Cache data hit count 1128396488
                                      Slowest loop: 6.69ms; fastest: 0.12ms
                                      === Storage ===
                                      SD card longest read time 3.2ms, write time 0.0ms, max retries 0
                                      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 168, MaxWait: 314759ms
                                      === MainDDARing ===
                                      Scheduled moves: 2, completed moves: 2, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
                                      === AuxDDARing ===
                                      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
                                      Segments left: 0
                                      HTTP is idle in state(s) 0
                                      Telnet is idle in state(s) 0
                                      File is idle in state(s) 0
                                      USB is idle in state(s) 0
                                      Aux is idle in state(s) 0
                                      Trigger is idle in state(s) 0
                                      Queue is idle in state(s) 0
                                      Daemon is idle in state(s) 0
                                      === Network ===
                                      Slowest loop: 39.91ms; fastest: 0.00ms
                                      Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                                      - WiFi -
                                      Network state is active
                                      WiFi Vcc 3.42, reset reason Unknown
                                      WiFi flash size 4194304, free heap 25336
                                      WiFi signal strength -65dBm, reconnections 0, sleep mode modem
                                      === DueX ===
                                      Read count 1, 0.09 reads/min
                                      Also, the config file is detailed bellow . There might be several issues in it , but as a first step I need to take care of the movements and the homing issues.
                                      Edit: formatting
                                      • Vetiundefined
                                        Veti
                                        this does not match your config
                                        Za and Zb are both driver 2
                                          campeancalin @Veti
                                          @Veti Thank you
                                            campeancalin
                                            The motors work fine, I still cant home the x and y
