    Release 3.2beta2 and mesh
    Beta Firmware
    140
    • Leblond
      Leblond last edited by
      good morning guys
      last night I installed Release 3.2beta2 and a strange thing happens
      when I go to mesh the plate, the graphical representation of the calibration does not come out on the screen and makes me see the one memorized previously, therefore totally useless, it had happened to me also with Release 3.2beta1, I thought that things had changed but nothing.
      • Leblond
        6/10/2020, 11:40:50 M122
        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2-beta2 running on Duet WiFi 1.02 or later
        Board ID: 08DGM-917NK-F23T0-6JTD0-3S06T-TYAJF
        Used output buffers: 3 of 24 (12 max)
        Static ram: 24028
        Dynamic ram: 100252 of which 44 recycled
        Exception stack ram used: 560
        Never used ram: 6188
        Tasks: NETWORK(ready,143) HEAT(blocked,294) MAIN(running,451) IDLE(ready,19)
        Owned mutexes: WiFi(NETWORK)
        Last reset 00:49:49 ago, cause: power up
        Last software reset details not available
        Error status: 0x00
        MCU temperature: min 18.6, current 31.1, max 31.3
        Supply voltage: min 23.2, current 23.5, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
        Driver 0: position 47672, standstill, SG min/max 0/122
        Driver 1: position 1616, standstill, SG min/max 0/150
        Driver 2: position 2768, standstill, SG min/max 0/3
        Driver 5: position 0
        Driver 6: position 0
        Driver 7: position 0
        Driver 8: position 0
        Driver 9: position 0
        Driver 10: position 0
        Driver 11: position 0
        Date/time: 2020-10-06 11:40:49
        Slowest loop: 17.35ms; fastest: 0.18ms
        === Storage ===
        Free file entries: 10
        SD card longest read time 4.3ms, write time 2.1ms, max retries 0
        Hiccups: 0(0), FreeDm: 169, MinFreeDm: 167, MaxWait: 2397106ms
        === MainDDARing ===
        Scheduled moves: 85, completed moves: 85, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
        === AuxDDARing ===
        Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
        Heater 0 is on, I-accum = 0.8
        Heater 1 is on, I-accum = 0.0
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        Daemon is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 15.92ms; fastest: 0.00ms
        Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
        HTTP sessions: 1 of 8
        • WiFi -
          Network state is active
          WiFi firmware version 1.23
          WiFi MAC address 84:0d:8e:b3:b4:8a
          WiFi Vcc 3.39, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 24200
          WiFi IP address 192.168.178.22
          WiFi signal strength -64dBm, reconnections 0, sleep mode modem
          Clock register ffffffff
          Socket states: 4 0 0 0 0 0 0 0
          === Filament sensors ===
          Extruder 0 sensor: ok
        • Leblond
          ok I just discovered that the page doesn't refresh, I have to do it manually with F5, as a browser I use chrome
          • Spanners
            Spanners last edited by
            Yeah same here, we still have a bug I believe.
            • chrishamm
              chrishamm administrators last edited by
              I can confirm this and I've got a fix ready. It will be part of the next beta.
              Duet software engineer
              • Leblond
                good boy👍 👍
                • Leblond
                  problem solved with Release 3.2beta3.2
                  • Leblond
                    thanks you guys
