    Analog input connection
    • kvlunagariyaundefined
      kvlunagariya
      I want to connect analog input 1-5volt to duet2 ethernet board. Is it possible ?
        dc42 administrators @kvlunagariya
        Maximum safe input voltage for the Duet is 3.3V. You will need to use a potential divider to reduce the voltage range.
          kvlunagariya
          Thanks for the reply.
