    Duet Laser Monitor Troubleshooting - M591
    Filament Monitor
    • scottypres
      scottypres last edited by
      Hi all,
      This is my first post, so hello!
      I just installed a duet laser filament monitor on my Railcore 2 and I'm having trouble with the calibration. I am using 1.75mm Carbon fiber Polycarbonate that has no gloss to it. The printed sensor enclosure parts are also made from this material. My min and max % values are approximately double what they should be.
      M591 D0 P5 C3 R140:260 E3.0 S1
      This is the widest min:max range I've used so far too complete prints without it giving an error that not enough movement is detected. Does anyone have any idea what the issue could be?
      • T3P3Tony
        it looks like you have a range from 163-211%, have you tried using the calibration factor (L" to centre it around 100%:
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_RepRapFirmware_Num_3
        I would try an "L" of 0.55 to start with
        www.duet3d.com
        • scottypres
          Thank you!
            If you can feed the filament past a toothed wheel before it reaches the filament monitor, that may put enough texture on it for the laser sensor to see it better.
