    Trouble with the Duet 2 on a Monoprice Maker Ultimate
    monopricemakerultimate wanhaoduplicator6 wanhaod6
    159
    • thejmather
      thejmather last edited by
      For those who don't know, Monoprice Maker Ultimate is a rebadged Wanhao Duplicator 6, or D6 for short.
      Ok, so I got a Duet 2 Wifi to replace the Wanhao controller board because I believed the board's extruder driver went out on me. In the process of setup and testing of the Duet 2, I of course uncovered that it was the cable going from the controller to the print head assembly... but alas, it's too late now, I'm invested!
      I used a multimeter to build this spreadsheet/diagram of the original wiring through the cable.
      I had to use the 2.x firmware in order to get the endstops to read correctly. From the factory they seem to be wired up for Normally Open, which the 3.x firmware didn't seem to like at all.
      I also have a BLTouch v3.1 installed, and swapped out the hotend thermistor with an E3D one I had handy since the stock thermistor didn't seem to want to register correctly. I have a P1000 I can install now, but I need some help before I go any further.
      So far as I can tell, everything "works". X, Y, Z, and E all move. I can heat up the hotend and extrude filament. I can run mesh compensation and see the bed leveling details. The bed heats up. Everything "works".
      However, I have yet to print anything successfully.
      Here is the M503 output I used for initial configuration:
      Send: M503
      Recv: echo:Steps per unit:
      Recv: echo:  M92 X80.04 Y80.04 Z400.48 E94.30
      Recv: echo:Maximum feedrates (mm/s):
      Recv: echo:  M203 X300.00 Y300.00 Z5.00 E25.00
      Recv: echo:Maximum Acceleration (mm/s2):
      Recv: echo:  M201 X3000 Y3000 Z100 E500
      Recv: echo:Acceleration: S=acceleration, T=retract acceleration
      Recv: echo:  M204 S800.00 T800.00
      Recv: echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s),  Z=maximum Z jerk (mm/s),  E=maximum E jerk (mm/s)
      Recv: echo:  M205 S0.00 T0.00 B20000 X10.00 Z0.40 E1.00
      Recv: echo:Home offset (mm):
      Recv: echo:  M206 X0.00 Y0.00 Z-0.15
      Recv: echo:PID settings:
      Recv: echo:   M301 P9.12 I0.41 D50.98
      Which lead me to this configuration:
      motor config
      The backwards/forwards stuff was trial and error, but everything seems to work as generally expected.
      I noticed that it looked like the Z axis wasn't moving as much as it should be. So I grabbed a random square thing I had handy, measured it to 35mm, and used G1 Z35 to put Z to 35mm, and sure enough, it didn't fit... but moving Z to 70 DID make it fit like I expected it to at Z35.
      So I bumped the Steps per mm from 400.98 to 800.96, re-calibrated the BLTouch and re-ran mesh leveling, and sure enough, now Z35 fits the 35mm item under it.
      I also figured out that it was set to speak "RepRap" when my slicer is configured to speak "Marlin" (as the MMU/D6 runs Marlin), so I updated the Duet's config to set it to Marlin.
      The point I'm at now, is I can print things without the horrible grinding noise that was happening before, but this is the result:
      print result 1
      print result 2
      For reference, this is the model I was trying to print.
      I'm pretty stumped, and somewhat frustrated. It's so close, and yet feels so far away from working! LOL...
      Here's the config I am using currently:
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Oct 08 2020 15:41:48 GMT-0400 (Eastern Daylight Time)
      G90                                         ; send absolute coordinates...
      M83                                         ; ...but relative extruder moves
      M550 P2"MPUltimate"                          ; set printer name
      M552 S1                                     ; enable network
      M586 P0 S1                                  ; enable HTTP
      M586 P1 S0                                  ; disable FTP
      M586 P2 S1                                  ; enable Telnet
      M569 P0 S0                                  ; physical drive 0 goes backwards
      M569 P1 S1                                  ; physical drive 1 goes forwards
      M569 P2 S0                                  ; physical drive 2 goes backwards
      M569 P3 S1                                  ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                            ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                     ; configure microstepping with interpolation
      M92 X80.04 Y80.04 Z800.96 E94.30            ; set steps per mm
      M566 X15000.00 Y15000.00 Z300.00 E1200.00   ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z300.00 E1500.00   ; set maximum speeds (mm/min)
      M201 X800.00 Y800.00 Z100.00 E500.00        ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E1000 I30            ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                     ; Set idle timeout
      M208 X0 Y0 Z0 S1                            ; set axis minima
      M208 X200 Y200 Z175 S0                      ; set axis maxima
      M574 X1 Y1 S0                               ; set active low and disabled endstops
      M574 Z1 S2                                  ; set endstops controlled by probe
      M307 H3 A-1 C-1 D-1                         ; disable heater on PWM channel for BLTouch
      M558 P9 H5 F120 T6000                       ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X31 Y-20 Z1                     ; set Z probe trigger value, offset and trigger height
      M557 X31:200 Y20:180 S20                    ; define mesh grid
      M305 P0 T100000 B4138 R4700                 ; set thermistor + ADC parameters for heater 0
      M143 H0 S120                                ; set temperature limit for heater 0 to 120C
      M305 P1 T100000 B4725 C7.060000e-8 R4700 X2 ; set thermistor + ADC parameters for heater 1 and remap it to channel 2
      M143 H1 S280                                ; set temperature limit for heater 1 to 280C
      M106 P0 S0 I0 F500 H-1                      ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M563 P0 D0 H1 F0                            ; define tool 0
      G10 P0 X0 Y0 Z0                             ; set tool 0 axis offsets
      G10 P0 R0 S0                                ; set initial tool 0 active and standby temperatures to 0C
      M501                                        ; load saved parameters from non-volatile memory
      T0                                          ; select first tool
      • Veti
        Veti last edited by
        @thejmather said in Trouble with the Duet 2 on a Monoprice Maker Ultimate:
        this is way to high try somthing like 600 for x and y
        X2 is not valid here. where did you connect the thermistor?
        thejmather 1 Reply Last reply Reply Quote 0
        • thejmather
          thejmather @Veti last edited by
          @Veti said in Trouble with the Duet 2 on a Monoprice Maker Ultimate:
          Ok, I'll bump it down to..
          M566 X600.00 Y600.00 Z300.00 E480.00   ; set maximum instantaneous speed changes (mm/min)
          Is the maximum speeds also going to need to be tweaked?
          ... though this came from
          which is in mm/s, though i see now it's mm/s^2, so maybe the correct way to convert it would be sqrt(3000) * 60 which is 3286? I dunno.
          I'll give M566 X600.00 Y600.00 Z300.00 E480.00 a shot.
          the gcode wiki says X is valid here...
          This is the config in the UI:
          ui thermistor config
          I was playing with it at some point to get it working and figured out I had it plugged into the thermistor input for E1 and not E0... I haven't changed it back yet, but I suspect that is the origin of it, since I don't have an E1 set up otherwise, only an E0.
          Veti 1 Reply Last reply Reply Quote 0
          • Veti
            Veti last edited by
            that is jerk in marlin. you are basically saying you can instantly go from 0 to 250mm/sec
            • Veti
              Veti @thejmather last edited by
              ok i give you that its valid, but its very unusual to specify this here.
                Phaedrux Moderator @thejmather last edited by
                That's a pretty easy fix. You just need a ! in front of the pin name to invert the signal. Since you are new to reprap firmware I would suggest giving RRF3 a try. It's more flexible and capable and still being developed long term.
                If you post your RRF3 config.g we can help you out.
                It looks like you figured out your layer skips though. It's important to mind the units. mm/min versus mm/s. Convert by multiplying or dividing by 60.
                thejmather 2 Replies Last reply Reply Quote 0
                • thejmather
                  Ahhh! Ok, that'll let me convert better. It seems like these tweaks mostly worked.
                  I'm still VERY confused why the Wanhao controller works with 400.48 steps for Z axis but the Duet 2 needs 800.96 to work right. I double-checked the cables last night and all of the wiring for Z matches X and Y. So weird.
                    Microstepping will also come into play in calculating steps per mm.
                    Z_steps_per_mm = (motor_steps_per_rev * driver_microstep) / screw_lead
                    The recommended default for the Duet is x16 microstepping with interpolation to x256 by the driver chip. So you would calculate based on x16. Maybe the microstepping for your old board was different?
                    • thejmather
                      thejmather @Phaedrux last edited by
                      @Phaedrux said in Trouble with the Duet 2 on a Monoprice Maker Ultimate:
                      Everything I was able to find said ~400 is the right answer... and most things seem to suggest the D6/MMU has 16x microstepping, which means it's a Tr8X8 screw... I dunno. It works, so I'm not really inclined to argue with it, but it sure is BIZARRE.
                      I can look at the Marlin firmware tonight and see if it specifies the microstepping anywhere... the up side of having installed the BLTouch previously, I guess, is I have the source code handy... lol.
                      I haven't been able to find a good reference for understanding /for sure/ which motor pins on the Duet go to which motor pins on the motors, but it seems odd that the Z axis motor would just be wired differently, too... so it's hard to say.
                      • thejmather
                        I'm pretty sure I tried the ! trick, but if I can get it working with V2, then I'll give V3 a shot again for good measure now that I feel like I know a bit more about what I'm doing.
                        • thejmather
                          So trying to get the same config on V3, I get:
                          M574 X1 S1 P"!xstop"                                   ; configure active-high endstop for low end on X via pin !xstop
                          M574 Y1 S1 P"!ystop"                                   ; configure active-high endstop for low end on Y via pin !ystop
                          and that ends up reporting that the endstops are triggered... which is the same as I get if I remove the !'s.
                          I also can't get the Z-probe to work with this setup. Followed this guide with the exception of using Heater3 instead of Heater7.
                          I am going to throw the 2.x firmware back on and print a calibration cube and see where I'm at on that front...
                          • thejmather
                            Forgot to add, here's what i've got for a V3 config:
                            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Fri Oct 09 2020 17:27:05 GMT-0400 (Eastern Daylight Time)
                            M550 P"MPUltimate"                                     ; set printer name
                            M569 P0 S1                                             ; physical drive 0 goes forwards
                            M569 P1 S0                                             ; physical drive 1 goes backwards
                            M569 P3 S0                                             ; physical drive 3 goes backwards
                            M92 X80.00 Y80.00 Z800.00 E94.30                       ; set steps per mm
                            M566 X600.00 Y600.00 Z24.00 E60.00                     ; set maximum instantaneous speed changes (mm/min)
                            M203 X7200.00 Y7200.00 Z300.00 E300.00                 ; set maximum speeds (mm/min)
                            M906 X1000 Y1000 Z1000 E1000 I50                       ; set motor currents (mA) and motor idle factor in per cent
                            M574 X1 S1 P"!xstop"                                    ; configure active-high endstop for low end on X via pin xstop
                            M574 Y1 S1 P"!ystop"                                    ; configure active-high endstop for low end on Y via pin ystop
                            M574 Z1 S2                                             ; configure Z-probe endstop for low end on Z
                            M950 S0 C"exp.heater3"                                 ; create servo pin 0 for BLTouch
                            M558 P9 C"^zprobe.in" H5 F120 T6000                    ; set Z probe type to bltouch and the dive height + speeds
                            M557 X31:200 Y0:180 S10                                ; define mesh grid
                            M308 S0 P"bedtemp" Y"thermistor" T100000 B4138         ; configure sensor 0 as thermistor on pin bedtemp
                            M950 H0 C"bedheat" T0                                  ; create bed heater output on bedheat and map it to sensor 0
                            M307 H0 B1 S1.00                                       ; enable bang-bang mode for the bed heater and set PWM limit
                            M140 H0                                                ; map heated bed to heater 0
                            M308 S1 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e1temp
                            M950 H1 C"e0heat" T1                                   ; create nozzle heater output on e0heat and map it to sensor 1
                            M307 H1 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
                            M950 F0 C"fan0" Q500                                   ; create fan 0 on pin fan0 and set its frequency
                            M106 P0 S0 H-1                                         ; set fan 0 value. Thermostatic control is turned off
                            Endstops read as triggered when they are not. Thermistors are reading at 2000. Total craziness. LOL!
                              Identify the phase pairs, then each pair goes together on either side of the board pins. As long as the pairs aren't crossed it doesn't matter which pair is on which side. You can change motor rotation direction in config.g.
                              https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
                                Then remove the ! from the pin name.
                                How do you have the endstops wired? Are they standard 2 wire endstops, or 3 wire with a PCB?
                                https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches
                                2000c on the temp would indicate a short circuit fault. Which heater pins are you using? Your config says e1temp, but e0temp would be the first temp sensor. Which one are you plugged into?
                                  What exactly doesn't work? Did you also change the deployprobe and retractprobe macros to use P0 instead of P3 or P7?
                                  • thejmather
                                    With or without the !, it reads as triggered on V3 firmware.
                                    They are 2 wire normally open.
                                    This config works fine on the V2 firmware.
                                    Am I going to need to change how they're wired up for the V3 firmware maybe? I think I have the lines connected to the two outside pins of the three pin connectors, but I'd have to double-check that.
                                    I apparently had it plugged into the E1 thermistor spot before... I moved it to E0 and it works as expected on the V2 firmware with
                                    M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
                                    I tried the config a couple different ways, even after moving it to the E0 input and setting it to E0temp, it still wouldn't work. Both still read at 2000 on V3.
                                    • thejmather
                                      Yeah, I fixed all that, and even tried manually sending:
                                      M280 P0 S10
                                      to which it responds with "servo 0 is not defined" (or similar -- i'm printing a calibration cube on v2 firmware now or I'd check).
                                        Servo 0 not defined would make sense if you're still using rrf2
                                        Can you send m122 and m98 p"config.g" and post the results ?
                                        It would be a lot easier if we just configured for rrf3 at this point.
                                          How are you switching between rrf2 and rrf3?
                                          • thejmather
                                            This is the million dollar question... for some reason, I had thought that just uploading the config zip file was enough.
                                            Your last comment lead me to check my assumptions, and yeah, it's still running 2.x...
                                            I'm trying to upload the bin via the web control panel now... I've managed to get web control panel to report that it's 3.x but diagnostics is still saying reprap is 2.05.1...
                                            Do I have to do a hard power cycle maybe?
                                              Ah, ok, then. That answers that.
                                              Here's how you should proceed with the updates.
                                              First make sure you're running 2.05.1, and it sounds like you are, but just to make sure you have all the files needed here's how you do a complete firmware update. It just involves uploading a single zip file for each version to the sys folder via the web interface.
                                              Start with the 2.05.1 zip file. Then upload the 3.0 zip file. Then 3.1.1. It'll reboot between each. Then you can upload your config zip file if you haven't already.
                                              Upload the whole zip file. don't extract it.
                                              https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                                              https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
                                              • thejmather
                                                Alright! This seems to be working a lot better. It got to 3.0.0 successfully, though it's been spinning for quite a while on 3.1.1.
                                                The temp sensors were working though.
                                                Still just waiting on it to come back up after the 3.1.1 upgrade though. Might have to go a more manual route for this one since it seems to not be coming back up...
                                                A Former User 1 Reply Last reply Reply Quote 0
                                                • A Former User
                                                  A Former User @thejmather last edited by
                                                  should take less than a minute; reset and try again if it takes longer.
                                                  • thejmather
                                                    thejmather @Guest last edited by
                                                    @bearer Yep, it just needed the ol' "turn it off and then on again" treatment. Let's see where I'm at functionality wise with 3.1.1 now that I'm not trying to run a v3 config on v2 firmware LOL...
                                                    • thejmather
                                                      Neat! It mostly seems to be working. Endstops are good. BLTouch is good.
                                                      I was warming things up to do a bed probe though, and got:
                                                      Error: Heater 0 fault: temperature rising much more slowly than the expected 1.7°C/sec
                                                      I don't see much for options in the config editor to counter this, though...
                                                      Config:
                                                      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Fri Oct 09 2020 21:30:59 GMT-0400 (Eastern Daylight Time)
                                                      M574 X1 S1 P"!^xstop"                                  ; configure active-high endstop for low end on X via pin !^xstop
                                                      M574 Y1 S1 P"!^ystop"                                  ; configure active-high endstop for low end on Y via pin !^ystop
                                                      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                                                      Phaedrux 2 Replies Last reply Reply Quote 0
