Mirror extruder movement without loosing filament management?
  • Is they any way to mirror extruder movement without loosing filament management?
    For now I setup just a mixing extruder with the ratio of 1:1.
    I have a really lightweight Cycloidal extruder with a NEMA 14 on my hotend and a big bowden extruder with just feeds the filament inside my printer enclosure so the small NEMA14 doesn't have to pull the filament so hard from outside.
    For now when you setup mixing extruder you lose filament management. My setup isn't an actually a mixing extruder. Note that the extruder have really different steps/per mm, then Cycloidal has 4250steps/per mm and then bowden 850steps/per mm
    I am running RRF 3.1.1.
