distinguishing between two kinds of pause
  • Hello,
    My printer has Duet wifi equipped with TriangleLab runout sensor.
    At the moment the only difference between an initiated pause to a runout pause is an additional message reporting which extruder has run empty.
    I would like to distinguish between pause.g to a pause which is being trigged by the runout sensor by invoking another macro file.
    I run RRF2.05.1 and currently unable to upgrade to RRF3 to due to various reasons.
    Should I set the runout sensors by M581 as an external trigger instead of M591 ? Is there another why?
    Your thoughts and suggestions are highly appreciated.
    Thank you,
    Elad
    I have it on the work list to add a new macro file for a pause caused by a filament problem.
