    duet 2 wifi Always Disconnecting from a wifi how can ifix it
    • Roei3d
      Roei3d last edited by
      duet 2 wifi Always Disconnecting from a wifi how can ifix it ? thnks for the help
      this is my g code and m122
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
      Board ID: 08DLM-996RU-N8PS4-7J9FL-3SN6L-9S9RR
      Used output buffers: 3 of 24 (17 max)
      Static ram: 25712
      Dynamic ram: 93220 of which 0 recycled
      Exception stack ram used: 464
      Never used ram: 11676
      Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,3752) IDLE(ready,160)
      Owned mutexes:
      Last reset 01:19:00 ago, cause: software
      Last software reset at 2020-10-14 19:01, reason: Hard fault, spinning module GCodes, available RAM 11552 bytes (slot 3)
      Software reset code 0x4033 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x0441f803 BFAR 0x3523e3a1 SP 0x200046dc Task 0x4e49414d
      Stack: 0041b6ab 00400576 61000000 7fe00000 00000000 00000000 3ff00000 00000000 404e0000 000007ff 0044c49b 00452d34 21001400 2000ba94 2000a0a4 00000000 00000000 200134e8 0041baf1 00000001 2000bba4 2000a0a4 2000ba90
      Error status: 0
      Free file entries: 9
      MCU temperature: min 40.0, current 42.6, max 44.4
      Supply voltage: min 23.9, current 24.3, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: ok, SG min/max 0/284
      Driver 1: ok, SG min/max 0/270
      Driver 3: ok, SG min/max 0/1023
      Date/time: 2020-10-14 20:20:31
      Slowest loop: 5.05ms; fastest: 0.07ms
      Hiccups: 0, FreeDm: 156, MinFreeDm: 151, MaxWait: 0ms
      === DDARing ===
      Scheduled moves: 18391, completed moves: 18370, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Heater 0 is on, I-accum = 0.3
      Heater 1 is on, I-accum = 0.4
      Segments left: 1
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is doing "G0 F13200 X59.417 Y137.482" in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 200.23ms; fastest: 0.08ms
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is running
      Failed messages: pending 0, notready 0, noresp 2
      WiFi firmware version 1.23
      WiFi MAC address XXXXXX
      WiFi Vcc 3.32, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 23152
      WiFi IP address XXXXXXX
      WiFi signal strength -74dBm, reconnections 0, sleep mode modem
      my gcode
      ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jun 14 2020 01:09:58 GMT+0300 (שעון ישראל (קיץ))
      M550 P"Ender 3 Pro BLV"                            ; set printer name
      M551 P"XXXXX"                                   ; set password
      M569 P0 S0                                         ; physical drive 0 goes backwards
      M569 P1 S0                                         ; physical drive 1 goes backwards
      M569 P2 S1                                         ; physical drive 2 goes forwards
      M569 P3 S0                                         ; physical drive 3 goes backwards
      M584 X0 Y1 Z2 E3                                   ; set drive mapping
      M92 X79.56 Y79.64 Z400 E415	                       ; set steps per mm
      M566 X600.00 Y600.00 Z24.00 E2000                  ; set maximum instantaneous speed changes (mm/min) (Jerk)
      M203 X6000.00 Y6000.00 Z300.00 E5000.00            ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000               ; set accelerations (mm/s^2)
      M906 X700 Y700 Z700 E660 I30                       ; set motor currents (mA) and motor idle factor in per cent
      M84 S10                                            ; Set idle timeout
      M208 X0 Y0 Z0 S1                        ; set axis minima
      M208 X245 Y210 Z240 S0                  ; set axis maxima
      M574 X1 Y1 S1                                      ; set active high endstops
      M574 Z1 S2                                         ; set endstops controlled by probe
      M307 H3 A-1 C-1 D-1                                ; disable heater on PWM channel for BLTouch
      M558 P9 H3 F320 T90000                             ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X38.2 Y0 Z0.980                            ; set Z probe trigger value, offset and trigger height
      M557 X40:235 Y20:225 S30                            ; define mesh grid
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      M305 P0 T100000 B4092 R4700                        ; set thermistor + ADC parameters for heater 0
      M143 H0 S90                                        ; set temperature limit for heater 0 to 80C
      M305 P1 T100000 B4092 R4700                        ; set thermistor + ADC parameters for heater 1
      M143 H1 S270                                       ; set temperature limit for heater 1 to 250C
      M106 P0 A22 S0 I0 F100 H-1                          ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S0 I0  H1   T45                             ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      ; Pressure Advance
      M572 D0 S0.05
      ; Retraction
      M207 S0.80 R0.0 F3000 T1800 Z0.0
      ; M207: Set retract length
      	; Parameters
      	; 	Snnn positive length to retract, in mm
      	; 	Rnnn positive or negative additional length to un-retract, in mm, default zero
      	; 	Fnnn retraction feedrate, in mm/minMiscellaneous
      M501                                               ; load saved parameters from non-volatile memory
      ; BLTouch startup
      G4 S2							; Pause a couple seconds
      M280 P64 S160						; Clear any alarms
      M402							; retract pin just in case
        Phaedrux Moderator @Roei3d last edited by
        @Roei3d said in duet 2 wifi Always Disconnecting from a wifi how can ifix it:
        Your signal strength is border line. Do you have the Duet inside an enclosure? How far are you from the access point?
        Are you using DWC 2.0.7?
