    DUET2 Ethernet | Y-Axis movement --> Timeout Webserver
    Duet Web Control
    38
    • Egris
      Egris last edited by
      i have updated my Duet2 Ethernet to Firmware V3.
      I ran into a Problem that long travel on Y-Axis causing the webserver to fail.
      I cant connect back.
      On the otherhand, X-Axis movment is no Problem..
      Anyone else having this Problem?
      No clue what to do.. Webserver is crashing each time a long Y-Travel going on...
      greetings
      Veti 1 Reply Last reply Reply Quote 0
      • Veti
        Veti @Egris last edited by
        @Egris said in DUET2 Ethernet | Y-Axis movement --> Timeout Webserver:
        V3.
        did you update to 3.1.1?
        did you update the wifi firmware as well?
        • Egris
          HI, yeah updated to 3.1.1.
          Duet 2 Ethernet needs wifi firmware?
          • Veti
            no my bad
            by crashing you mean you can not connect to the webserver anymore?
            do you have a paneldue?
            • Egris
              yes, cant connect back. I have no Panel due. For the ongoing print there is no drawback.
              • Veti
                Veti last edited by
                what browser are you using?
                is usb connected?
                • Egris
                  tryed Edge and Firefox, no diffrence. USB is not connected at the moment
                    Can you please post your config.g and homing files as well as the output of M122 and M98 P"config.g".
                    How are you commanding the long Y axis move? How long?
                    What do you mean by the webserver failing or crashing? what exactly is happening?
                    • Egris
                      Here is the config File.
                      When I do a Y-Axis Move "100mm" via Move-Botton on Web-Control the Webserver timed out and i cant reconnect. Only after a powercycle i can connect back.
                      When i move the X-Axis via the Buttons there is no problem..
                      Started a print, Can post the other informations tomorrow.
                      Best regards
                      config.g
                        And homing works normally?
                        In addition to the other info requested, what version of DWC is installed?
                        If you send G91 G1 Y100 from the console does it have the same effect?
                        • Egris
                          First of all thank you for all of your help.
                          Finally I found my problem what is causing the webserver to stop working when y-axis is moved by firmware or manually pushed.. :D.
                          The wires of the Y-Axis Stepper where to close to my Ethernet-Cable.
                          Worked perfectly for 2 years until now..
                          electro magnetic disorder
