Heaters disappear in RRF Config Tool
I'm using the "RRF config Tool" for the initial setup of required files.
My system consists of a Duet 3 and 3 expansion boards.
In total I have 5 heaters. Every set of Heater, temperature element and extruder are connected to the same expansion board. The heater paragraph at section I/O mapping shows the bedheater and the 5 hotend heaters. (see picture Heaters.jpg)
The heaters section is showing the hotbed and the 5 defined hotend heaters (see picture heater section).
Every set of extruder, hotend heater and thermo element will be part of a tool element, i.e. a total of 5 tools.
So far so good, however when looking at the Tools section, suddenly, I only have E0, E1, E3 and E4, suddenly E2 disappeared. Is this a bug in the tool? Am I doing something incorrectly?
Of course, I know that I can adjust the files manually, no problem there, However when I misunderstood something than the manual adjustment will not work.Kind regards,
Harald Witmer
@ahwitmer said in Heaters disappear in RRF Config Tool:
3 expansion boards.
Do you mean the 3HC expansion board, or tool boards?
What does your i/o mapping page look like?
Can you post the resulting config.g and config.json it produces so I can compare against?
Indeed, I mean the 3HC expansion boards, I have three of them.
Attached, you find the Config.json and the config.g files
Thank you for your help.
Thanks. I've been able to reproduce it in the tool. However, it looks like it's only a display issue in the tool as the gcode produced includes all the correct tools and heaters.
; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M563 P1 D1 H2 F0 ; define tool 1 G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C M563 P2 D2 H3 F1 ; define tool 2 G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C M563 P3 D3 H4 F1 ; define tool 3 G10 P3 X0 Y0 Z0 ; set tool 3 axis offsets G10 P3 R0 S0 ; set initial tool 3 active and standby temperatures to 0C M563 P4 D4 H5 F0:2 ; define tool 4 G10 P4 X0 Y0 Z0 ; set tool 4 axis offsets G10 P4 R0 S0 ; set initial tool 4 active and standby temperatures to 0C
H1, H2, H3, H4, H5 all accounted for.
@Phaedrux
Could have come to this myself pfff. Sometimes you get into a loop to start, trying to solve it.
Thanks Phaedrux for the very quick reply!So finally it is a bug in the webapp. Who do I report this to?
Consider it reported.
