3.1.1 on Duet3 6HC +3HC +SBC intermittent disconnects.
  • It all started with the Webinterface going down on last print, it showed 71% and the print was finished. Couldn't refresh it either.
    I rebooted the Pi and started another job.
    When I checked on it it was jerking and had done this for half an hour according to logs, connecting and disconnecting from about 15 minutes into the print.
    It was still printing but jerking on and off. See video below:
    https://youtu.be/462bg3IgAnc
    2020-10-20 21:29:41	Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
    2020-10-20 21:28:40	Connection to Duet established
    2020-10-20 21:28:40	Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
    2020-10-20 21:28:39	Connection to Duet established
    2020-10-20 21:28:39	Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
    2020-10-20 20:15:41	m204
    Maximum printing acceleration 1500.0, maximum travel acceleration 4000.0
    2020-10-20 20:14:19	Height map loaded from file heightmap.csv
    2020-10-20 20:14:19	Leadscrew adjustments made: -0.036 0.010 0.028, points used 3, (mean, deviation) before (0.001, 0.023) after (0.000, 0.000)
    Here are the board diagnostics:
    2020-10-20 22:00:36	m122
    RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
    Board ID: 08DJM-956L2-G43S4-6JKDD-3SJ6L-TB62G
    Used output buffers: 1 of 40 (14 max)
    Static ram: 154604
    Dynamic ram: 163936 of which 44 recycled
    Exception stack ram used: 544
    Never used ram: 74088
    Tasks: NETWORK(ready,1972) HEAT(blocked,1088) CanReceiv(suspended,3412) CanSender(suspended,1392) CanClock(blocked,1436) TMC(blocked,68) MAIN(running,2672) IDLE(ready,76)
    Owned mutexes:
    Last reset 49:57:19 ago, cause: software
    Last software reset at 2020-10-18 20:03, reason: User, spinning module LinuxInterface, available RAM 74276 bytes (slot 1)
    Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
    Error status: 0
    MCU temperature: min 38.5, current 42.4, max 42.8
    Supply voltage: min 27.9, current 32.0, max 32.0, under voltage events: 0, over voltage events: 0, power good: yes
    12V rail voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0
    Driver 0: ok, reads 60978, writes 106 timeouts 0, SG min/max 0/1023
    Driver 1: ok, reads 60978, writes 106 timeouts 0, SG min/max 0/1023
    Driver 2: standstill, reads 60984, writes 101 timeouts 0, SG min/max 0/103
    Driver 3: standstill, reads 61036, writes 49 timeouts 0, SG min/max 0/1023
    Driver 4: standstill, reads 61037, writes 49 timeouts 0, SG min/max 0/1023
    Driver 5: standstill, reads 61037, writes 49 timeouts 0, SG min/max 0/1023
    Date/time: 2020-10-20 22:00:36
    Slowest loop: 1006.46ms; fastest: 0.14ms
    === Storage ===
    Free file entries: 10
    Hiccups: 0(0), FreeDm: 372, MinFreeDm: 313, MaxWait: 86366307ms
    === MainDDARing ===
    Scheduled moves: 80670, completed moves: 80630, StepErrors: 0, LaErrors: 0, Underruns: 439, 1045  CDDA state: 3
    === AuxDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
    Heater 0 is on, I-accum = 0.1
    Heater 1 is on, I-accum = 0.0
    Segments left: 0
    Movement lock held by null
    HTTP* is ready with "M122" in state(s) 0
    Telnet is idle in state(s) 0
    File* is ready with "G1 X248.397995 Y209.645996 E0.009770" in state(s) 0
    USB is idle in state(s) 0
    Aux is idle in state(s) 0
    Queue* is idle in state(s) 0
    LCD is idle in state(s) 0
    SBC is idle in state(s) 0
    Daemon* is idle in state(s) 0 0, running macro
    Aux2 is idle in state(s) 0
    Code queue is not empty:
    5 of 16 codes have been queued.
    === Network ===
    Slowest loop: 1.44ms; fastest: 0.01ms
    Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
    HTTP sessions: 0 of 8
    - Ethernet -
    State: disabled
    Error counts: 0 0 0 0 0
    === CAN ===
    Messages sent 1019462, longest wait 8ms for type 6029
    === Linux interface ===
    State: 0, failed transfers: 94
    Last transfer: 21ms ago
    RX/TX seq numbers: 60047/54289
    SPI underruns 94, overruns 94
    Number of disconnects: 1
    Buffer RX/TX: 1464/2688-0
    === Duet Control Server ===
    Duet Control Server v3.1.1
    File:
    Buffered code: G1 X247.232 Y209.454 E0.00977
    Buffered code: M107
    Buffered code: G1 X247.353 Y208.670 E0.02260
    Buffered code: G1 X247.399 Y208.106 E0.01613
    Buffered code: G1 X247.525 Y207.146 E0.02760
    Buffered code: G1 X247.639 Y205.227 E0.05481
    Buffered code: G1 X248.778 Y205.227 E0.03247
    Buffered code: M107
    Buffered code: G1 X248.624 Y205.565 F18000.000
    Buffered code: G1 X248.228 Y205.412
    Buffered code: G1 F1800.000
    Buffered code: G1 X248.117 Y207.188 E0.11391
    Buffered code: G1 X248.010 Y208.011 E0.05314
    Buffered code: G1 X247.942 Y208.725 E0.04591
    Buffered code: G1 X247.858 Y209.258 E0.03456
    Buffered code: G1 X247.825 Y209.461 E0.01232
    Buffered code: G1 F14400.000
    Buffered code: G1 X247.858 Y209.258 E-0.03250
    Buffered code: G1 E-0.96750 F2400.00000
    Buffered code: G1 X243.838 Y205.227 F18000.000
    Buffered code: G1 E1.00000 F2400.00000
    Buffered code: G1 F900.000
    Buffered code: G1 X243.726 Y207.108 E0.05373
    Buffered code: G1 X243.601 Y208.064 E0.02747
    Buffered code: G1 X243.555 Y208.623 E0.01600
    Buffered code: G1 X243.428 Y209.454 E0.02395
    Buffered code: M107
    Buffered code: G1 X243.398 Y209.646 E0.00977
    Buffered code: G1 X242.203 Y209.646 E0.05995
    Buffered code: G1 X242.232 Y209.454 E0.00977
    Buffered code: M107
    Buffered code: G1 X242.353 Y208.670 E0.02260
    ==> 1360 bytes
    Daemon:
    Finishing macro daemon.g, started by system
    > Next stack level
    Code buffer space: 1392
    Configured SPI speed: 8000000 Hz
    Full transfers per second: 27.64
    File /opt/dsf/sd/gcodes/estop_Spring.gcode is selected, processing
    2020-10-20 22:00:36	Connection to Duet established
    2020-10-20 22:00:36	Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
    The led on the toolboard was blinking fast and I couldn't get a diagnostics:
    2020-10-20 22:04:13	Connection to Duet established
    2020-10-20 22:04:12	Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
    2020-10-20 22:04:12	M122 b1
    Error: M122: Response timeout: CAN addr 1, req type 6024, RID=23
    2020-10-20 22:04:11	Connection to Duet established
    2020-10-20 22:04:11	Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
    Any idea what's wrong?
    I think DSF disconnecting from RRF is a side-effect of CAN timeouts. Please check your CAN wiring and make sure you do not have any loose contacts.
    Starting from software version 3.2, RRF will no longer disconnect when a CAN instruction blocks for a while.
  • After powercycle it printed fine.
