    Buffer problem?
    978
      Phaedrux Moderator @Tinchus
      Alright, so using 16mm3/s you can find a max print speed based on your chosen height and width.
      Max Suggested Speed = Volumetric Limit / ( Layer Height * Extrusion Width)
      So assuming 0.4 width and 0.2 height you could print at 200mm/s and maintain the flow rate. However, it's going to depend on the part being printed whether you're able to cool it fast enough or print the details at that speed.
