Cnc pendant
Hi all
I’m currently working on a pendant for my workbee but I’m having trouble understanding the wiring from the website [https://duet3d.dozuki.com/Wiki/CNC_Pendant?fbclid=IwAR2UgtfMSKndaqPSMmajGr0cM7ckZ_YpTO2wJWTcJhvPJfYBB3U1xMq81eg#Section_Parts_needed](link url)
Do I need to cut and solder the wires from the Pendant (I have the pendant from Banggood listed on this page) to the nano pro and then solder an Extra cable to connect to the PanelDue port?
Thanks
@Sp00kie13 said in Cnc pendant:
That's what I did, because I wasted to use a thinner cable than the one supplied with the pendant. You could re-use the same cable, but you would only use the +5V, GND, and one other wire in it (or two other wires if you need the PanelDue pass-through).
