DWC Layer chart stuck at layer 1
  • Hi,
    While printing a simple cube I noticed the layer chart doesn't do anything, it remains at layer 1. Also the text above the layer chart doesn't update layers, only percentage print time.
    RRF 3.1.1 , DWC 3.1.1
    Is this a bug or is there a setting I'm unaware of ?
  • @mbunjes
    have you tried a different slicer?
  • No, I have Cura 4.7.1 but no other slicers.
    Could it be something in the start or end codes ?
  • Moderator
    @mbunjes said in DWC Layer chart stuck at layer 1:
    Most likely. Please share a sliced gcode file.
  • Moderator
    T0
    M190 S60
    M104 S205
    M109 S205
    M82 ;absolute extrusion mode
    G28 ;Home
    G92 E0
    G1 F12000 X180 Y200 E5
    G1 F3600 E25 ; Prime
    G1 Z5 ; Raise Nozzle
    G1 F3600 X0 Y0 Z0.3 ; Goto x0y0 – Release backpresssure
    G92 E0 ; Zero extruder
    G29 S1
    G1 F6000 ; Print
    M83 ;relative extrusion mode
    G10
    ;LAYER_COUNT:125
    M572 S0.000000 D0 ;added by LinearAdvanceSettingPlugin
    ;LAYER:0
    M107
    M204 T2000
    M566 X900 Y900
    G1 F600 Z1.2
    ;MESH:flow_cube_0.8.stl
    G0 F7500 X181.95 Y178.05 Z1.2
    M204 P2000
    ;TYPE:WALL-OUTER
    G1 F600 Z0.2
    It could be this line G1 Z5 ; Raise Nozzle which I don't think you really need.
    Followed by this line G1 F3600 X0 Y0 Z0.3 ; Goto x0y0 – Release backpresssure you can try adding ;E0 after the Z0.3
    It also looks like cura is adding it's own Z moves before finally moving to the layer height. I don't think I've seen it do that before.
    G1 F600 Z1.2
  • Ok, thanks. I'll give it try.
