Simple power-off solution for duet
  • In my HEVO I have SSR installed and one works well but in my converted Artillery Genius I didn't wanted to mess with wires so I decided to use simple remote switch with small script to automatically turn off printer when temperature is below treshold.
    I used Sonoff S26 switch with tasmota installed.
    Then on raspebbery pi I have python script executed every 5 minutes by cron.
    Script is here https://github.com/pmarkiewicz/duet-off
    There is no config file to make this simple. Everything is in one script.
    Conditions to disable printer are:
    • active temperature set to -1
    • printer is idle
    • current temperature for heater with -1 is below 45 deg
    To "install" run
    crontab -e
    and add line
    5 * * * * /usr/bin/python3 /home/pi/duet-off.py
