Warnings when using Load Filament but shouldn't get them
  • Here's my load macro at the bottom. Why is the machine telling me the following error when there is no extrusion called for while the machine is cold?
    1:42:35 PMWarning: Tool 1 was not driven because its heater temperatures were not high enough or it has a heater fault
    1:42:31 PMM701 S"PETG"
    M703
    M291 P"Please wait while the nozzle is being heated up" R"Loading PETG" T5 ; Display message
    G10 S240 ; Set current tool temperature to 240C
    M116 ; Wait for the temperatures to be reached
    M291 P"Feeding filament..." R"Loading PETG" T5 ; Display new message
    M83 ; Extruder to relative mode
    G1 E120 F6000 ; Feed 120mm of filament at 100mm/sec
    G1 E10 F300 ; Feed 10mm of filament at 5mm/sec
    G4 P1000 ; Wait one second
    M292 ; Hide the message
  • Moderator
    Firmware 1.17 on a Duet Maestro I assume?
    Is it waiting for the temp to be reached?
    Does the error happen immediately or does it happen after it waits for the temp to be reached?
